car wont startplease help!!!
Old Apr 11, 2012 | 01:18 AM
ChevyFreek's Avatar
Car: 87 camaro/ 78 gmc serria classic
Engine: 2.8 soon to be 350/ 350
Transmission: 700r4/ turbo 350
Axle/Gears: have no clue.
Ok so i just did a tune up on my camaro 2.8 plugs, wires, cap, rotor. and still wont start, i have fuel, spark, just no starting.it turns over hard has scene i got it, i assume it is my timing seeing as how thats what the problem was for the last owner. anything else it might be before i start re-timing it?
Old Apr 11, 2012 | 02:42 AM
project89's Avatar
Re: car wont startplease help!!!
if it has spark and fuel, more then likley ur timming is 180* off, check the order of ur plug wires and make sure its right.
did u happen to remove the distributor when u did the tuneup?
Old Apr 11, 2012 | 04:10 AM
ChevyFreek's Avatar
i didn't, so the order on the block is
65
43
and on the disturber is
6 1
5 2
4 3
I will try swaping my timing 180 degrees and hope that helps. thank you
Old Apr 11, 2012 | 05:26 PM
project89's Avatar
u may have to remove the dizzy cap and verify which terminal is number 1
some times a previous owner if they pull the dizzy will just drop it back in and use the terminal closest to the rotor as the number 1 instead of actually putting it in the right place
Old Apr 13, 2012 | 12:37 AM
ChevyFreek's Avatar
dizzy cap?
Old Apr 14, 2012 | 06:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Distributor cap... Dizzy cap.
Firing order is in numerical order 1-6. #1,3,5 PASSENGER'S side.
Pick a terminal to use as #1 and remove and reinstall the dizzy so that the rotor points to that terminal with #1 on the firing stroke (TDC). It will either run or need to have the wires for #1 and 4 switched and the firing order reset from there.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
