2.8 to 3.1 Carbed
Old Apr 24, 2012 | 05:09 PM
SpecialEditon84's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: Pontiac 2.8 L V6
Transmission: Automatic 4spd
Axle/Gears: Stock
2.8 to 3.1 Carbed
Ok, so heres the deal. My buddy says fuel injection is the cool thing and you get so much more ponies with it. This may be true. But, when I think of a muscle car its a big motor with a carb on the top with chrome valve covers and air intake. So heres what I was thinking. I want to convert my 2.8 to a 3.1 but, I need all the parts out of a 3.1. But, the problem is I don't want fuel injection. I want a carb on the top. Preferably a 4 bbl. So i can put a round chrome air cleaner on the top. Is there any way I can do that with a 3.1? I know you can do it to a 2.8 but its EXPENSIVE. I mean, I want to have a 3.1 carbed with chrome headers which I got and chrome valve covers which I also have. Any thoughts?
Old Apr 24, 2012 | 05:34 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Re: 2.8 to 3.1 Carbed
The 2.8, 3.1 and 3.4 engines are all the same block so you'd have to use the carb kit for the 2.8, unless your 2.8 is already carb'd (I don't know if they ever were?). I'd say it probably isn't worth it of your current setup still runs fine. Though you might be able to fabricate a mount and hose so you could use one of those chrome air cleaners over the plenum if you wanted.
The other thing you could do is keep the stock setup and polish the aluminum plenum to a mirror shine, though niether of those options has the same sound as an old carb'd engine.
Old Apr 24, 2012 | 06:14 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
He has a pre 85 carbed 2.8L currently in the car.
Im his buddy that said that he should go fuel injected...I just like EFI. better thats all. Carbs confuse me, as I just can't hook a computer up to it and tune it like you can with EFI.
What he's saying that is he wants to just mount the carb set up on the 2.8L he has at the moment. Any block post 85 2.8/3.1/3.4L is beter then that pre 1985 one you've got, IMO
I can't say it would work forsure as I've never seen/heard anyone go from a carbed 2.8L to a 3.1/3.4L block with the carbed intake system on the top. Usually its the otherway arround.
Im sure someone wil chime in on this that knows whats going on as I have no idea on this one.
Old Apr 24, 2012 | 06:25 PM
project89's Avatar
his carb setup will swap ontop any of the rwd v6's
2.8/3.2/3.4
he just needs to swap his current intake and carb,along with distributor onto the new engine
in order to do a 4bbl he would have to buy the edelbrock manifold base and 4bbl carb top ,and then the holley 390cfm 4bbl carb which will run almost 1k for the carb intake and intake top
1k could be put to much better use on that engine then putting a 4bbl carb and intake on it
Old Apr 26, 2012 | 04:41 PM
Axle/Gears: Stock
Well thanks everyone. I mean like I said I just love carbs and I'm happy with my V6.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
spartanreaper
Sep 25, 2015 07:22 PM
rjcme
Sep 5, 2015 01:23 PM
