What is wrong with my rs' fuel system?
Old May 18, 2012 | 01:12 PM
redrumcrazykid's Avatar
Car: 1992 rs heritage edition
Engine: 3.1L
Axle/Gears: stock
O.K! I have a 1992 rs. I replaced the fuel pump by cutting out a trap door in the trunk. I also replaced the fuel filter. When I turn the key I hear the fuel pump kick on for a couple of seconds BUT, no fuel is pumped through the lines. I also replaced the fuel pump relay. What else could the problem be? The sending unit?
Old May 18, 2012 | 01:31 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: What is wrong with my rs' fuel system?
If you didn't do anything wrong you may need to open up all the lines and blow through to check for some sort of blockage.
Old May 18, 2012 | 01:43 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
by fuel filter, you do mean the little canister inline under the rear driver seat right? not just the sock on the FP?
You now have to disconnect the fp under the rear seat and turn the key without being under there and see if fuel sprays out, if it does, diagnose why it doesn't make it through the line up to the engine by disconnecting the engine bay fuel lines. if it doesn't come out tehre, disconnect the other side of the fuel filter, to see if the fuel filter is defective and not letting it go through, and from there, if it doesn't spray out there, go up to the fuel pump assembly itself and go ahead and see if the fuel comes out of the output on the assembly. basically take it all the way back to the sending unit to see where it starts spraying so you can diag which line it is. when you hacked your lines, you didn't hook the return line up the output side did you? Been a while since i've seen the top of the fuel tank, not sure how easy that is to mix up or if it is even possible.
Old May 18, 2012 | 01:54 PM
Engine: 3.1L
Axle/Gears: stock
I diconnected the lines where I hacked them right by the sending unit and no fuel comes out when I turn the key. I replaced the fuel filter under the car as well as the fuel sock and pump in the tank. I just located the fp fuse and its not that. and like I said I replaced the relay. It has to be the sending unit right?
Old May 18, 2012 | 01:55 PM
Engine: 3.1L
Axle/Gears: stock
and theres no way in hell I mixed up the lines.
Old May 18, 2012 | 02:23 PM
84redta's Avatar
just a question, no inference made by the statement.
when you did the fuel pump, i'm guessing it came with a new rubber fuel line for the sending unit connection, did you use hose clamps on that? could have blown off if not tight or something silly inside the tank/sending unit.
Old May 18, 2012 | 03:17 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
But if the pump stops running it should mean it's built up pressure. Got to start disconnecting.
Old May 18, 2012 | 03:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Pump wires connected in reverse? Would make the pump, pump backwards.
RBob.
Old May 18, 2012 | 04:18 PM
Engine: 3.1L
Axle/Gears: stock
LORD HELP ME! ....it was out of fuel..... the fuel gage is wrong. WTFFFF!!! At least it runs now
Old May 18, 2012 | 06:06 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
LORD HELP US! Nobody thought to suggest that!
Old May 18, 2012 | 06:12 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
lol
RazorN8
Jan 7, 2022 11:44 AM
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
