83 2.8L turbo?
Old May 28, 2012 | 07:20 PM
DiligentWaffles's Avatar
Car: 1983 Camaro
Engine: 2.8L V6
Transmission: manual 5-speed
83 2.8L turbo?
I have a sport coupe (manual) new tranny and I was wondering if you guys have any tips or steps on going about putting a turbo on my stock engine... decent shape and only 63k miles....and yes it currently runs
Old May 28, 2012 | 07:26 PM
project89's Avatar
Re: 83 2.8L turbo?
im all for putting turbos on these engines BUT seeing how u have the weaker carbed engine i highly suggest against it
the carbed 2.8 motors have cranks with smaller mains , and are prone to breaking and spining bearings, the other difference is the heads have smaller valves then the fuel injected motors
to do a proper carb setup with a turbo u would have to ditch the factory carb and get an eldelbrock intake with the 4bl carb upper plenum which is a few hundred bucks
then u would need a holley 4150 series carb with mechanical secondarys and i dont belive they make one small enough to run on the v6, though id have to poke around a bit but u may be able to modify a holley 2 barrell carb to work wich would save u the cost of the intake since it should bolt onto the factory one
if u really want to go turbo my best advice would be to do an engine swap and ecm swap first
i would swap in a 90-92 ecm and harness and 3.1L engine
or a 93-94 3.4 motor with the 90-92 ecm and harness
though just getting a 3.1 out of a 90-92 with ecm and harness would be much easier
this will pick up a bunch of power over what u have now and will be much better suited to being turbocharged down the road
Old May 28, 2012 | 07:29 PM
project89's Avatar
Re: 83 2.8L turbo?
i also see u live in the state of ca
the 3.1 and ecm swap will be legal if u retian all the emission equip, which u would get with the new motor
but u will never get a turbo setup to pass inspection in that state with the hellish emisions laws
u would have to remove it and go back to stock everytime u needed an inspection , unles su know somone who will pass ur car no matter what but from what i hear thats very hard to do in ca
Old May 28, 2012 | 07:33 PM
Car: 1983 Camaro
Engine: 2.8L V6
Re: 83 2.8L turbo?
ok thanks...I wasnt sure if whether or not i needed to do a swap before I went turbo... i guess ill stop by the local pick n pull... oh n also would my tranny fit the "new" engine after I swap? I would like this to be budget friendly
Old May 28, 2012 | 07:36 PM
Car: 1983 Camaro
Engine: 2.8L V6
Re: 83 2.8L turbo?
about that... lets say i know a guy haha
Old May 28, 2012 | 07:37 PM
project89's Avatar
Re: 83 2.8L turbo?
u could very well turbo ur current engine if u wanted to but i wouldnt
yes ur trans will bolt to the new engine
do u have the 5 speed or 4 speed trans ?
the clutch may become an issue at some point depending on how much power u want to make anything more then say 7psi its real iffy if the stock clutch will hold or start slippping .
by 12 psi i can tell u the stock clutch will deffinatly start slipping
Old May 28, 2012 | 07:39 PM
project89's Avatar
Re: 83 2.8L turbo?
if u find a donor car in the junkyard dont forget to grab the sending unit out of the fuel tank, though u can prolly modify ur current one to accept a fuel injection fuel pump
once u get the ecm and motor swap done u could get it turboed for around 8-900 bucks if u can do all ur own work or dont have to pay for labor
Old May 28, 2012 | 07:41 PM
Car: 1983 Camaro
Engine: 2.8L V6
Re: 83 2.8L turbo?
5 speed...ill buy aftermarket clutch no prob but right now its stock clutch....
Old May 28, 2012 | 07:45 PM
project89's Avatar
Re: 83 2.8L turbo?
stick with a spec clutch specclutches.com or whatever it is
the ram clutches are junk and dont hold worth a dam
edit
http://www.specclutch.com/
a member here who bought a stage 3 clutch for his car had goten it so all tgo members got a discount i dont know if thats still active though
Old May 28, 2012 | 08:32 PM
Car: 1983 Camaro
Engine: 2.8L V6
Re: 83 2.8L turbo?
ok Ill check it out...would you advise to get stage 2? or just stage 1? is there a big difference in performance?
Old May 28, 2012 | 09:03 PM
project89's Avatar
Re: 83 2.8L turbo?
they are rated by holding power.
if u do a 3.1 swap and throw a cam in and port the heads/intake i would go with a stage 2 actually make that a stage 3 since its cheaper and holds more power
if ur just going to turbo the stock engine without any other work a stage 1 should be just fine
the last 5 speed camaro i helped turbocharge i told him to go with a stage 3 clutch since he had a 3.4 with a cam and fully ported heads and intake
on my 3.1 with heads/cam/intake it made 370 ftlbs of tq at the rear tires with a messed up ignition system so say 430 ftlbs at the flywheel and that wa sonly at 9 pounds of boost
relistically now that the ignition system is fixed it prolly makes dam near 500ftlbs at 9 psi
so going to the stage 2/3 clutch wouldnt be a bad idea
stage 1 holds 485ftlbs
stage 2 holds 550ftlbs
stage 3 holds 650 ftlbs
though i should warn u about the t5 transmission it will give up long before the stage 1 clutch if u abuse it
if u dont powershift it or sidestep the clutch it will last though
id say the stage1 is a lil less then what u will need in holding capacity if ur going to go for max power and the stage 3 is 20 bucks cheaper then the stage 2
so its upto u between the stage 2 or 3
this page will tell u about each stage of clutch
http://www.specclutch.com/products
Old May 28, 2012 | 09:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 83 2.8L turbo?
come on now, the fagoel superchargers were desinged for the early carb motors in trucks, pushing 5-7psi and people didn't have any trouble.
Old May 28, 2012 | 09:26 PM
project89's Avatar
Re: 83 2.8L turbo?
they were made for the fuel injected tbi cars and trucks , and they didnt make much power
Old May 28, 2012 | 09:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 83 2.8L turbo?
first ones were carb, the TBI plate came later.
owned a NOS one with 2 barrel carb plate.
The early ones were also cogg belt, once it went TBI they had serp belt adapter.
here is the build thread for the one I sold, the guy did go to serp setup but not TBI, he got a 4barrel adapter made.
http://www.s10forum.com/forum/f30/83...3/index22.html
Old May 30, 2012 | 07:04 PM
83Berli's Avatar
Car: '83 Berlinetta
Engine: 2.8L V6
Transmission: 200C
Re: 83 2.8L turbo?
if he did go with the 4 barrel carb, doesn't he need a turbocharger housing? such as...
http://www.summitracing.com/parts/TNT-10351/
does it matter if the secondaries are mechanical or vacuume since it's in the housing?
Old May 30, 2012 | 08:11 PM
project89's Avatar
Re: 83 2.8L turbo?
to use a vacum secondary carb u have to have the carb completly enclosed in a box , not just a carb hat.
i belive paxton had a carb box they used to make might have been vortec, but either way they dont work to well
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
bplessy
Sep 30, 2015 12:14 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
