I need EGR and Cold start block off plates.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: I need EGR and Cold start block off plates.
does the egr footprint look like a felpro 70954 ?
http://www.ebay.com/itm/CHEVY-S-10-8...ht_1019wt_1063
Engine: Lb9
Transmission: M20
I don't believe any one makes one . It is easy to use a standard motors VG91 (acdelco 213-4516) as a template.
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
1/4" aluminum or steel stock, a dremel , a cut off wheel , a drill, a couple drill bits.
You'll be wanting to block off everything once you start making them. Lol
