firebird vs. fiero manifolds
Old Jun 30, 2012 | 12:23 AM
crazybird's Avatar
Car: 1987 firebird
Are the intake for the 2.8's the same? better yet. are the motors in general the same?
Old Jul 1, 2012 | 10:04 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: firebird vs. fiero manifolds
Intake manifolds are similar but different. Fiero mounts the starter on the other side of the block. Leave the Fiero 2.8 alone and go find a '93-'95 3.4L.
Old Jul 1, 2012 | 10:56 AM
crazybird's Avatar
Car: 1987 firebird
I am asking becaue I want to get the egr and cold start block off plates. but i can only find them for the fiero. will the 3.4 manifold fit on the 2.8? just curious.
Old Jul 1, 2012 | 11:19 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
The 3.4L upper intake will fit but needs modifications to work correctly.
Yes the motors are the same. Pre 85 have some internal differences and carbs but all iron headed 2.8 and 3.1L 660's are about 80% the same IIRC. Just little things are different through the years... MAF or speed density, 7th injector, dif. egr, exc..
Old Jul 1, 2012 | 11:23 AM
crazybird's Avatar
Car: 1987 firebird
Im sorry. I just want to know if the egr and cold start plates will fit on my car. Im still sort of confused. Do you know of a place I can get plates that will def work?
Old Jul 1, 2012 | 03:52 PM
project89's Avatar
do not block off the coldstart injector , unless urs is broken and u cant find a new one.
the egr is very simple to make a blockoff plate for.
and i dont belive the fireo egr plate will work on ur 2.8
deracer
Apr 11, 2016 12:04 AM
transaero
Aug 31, 2015 01:14 AM
theshackle
Aug 22, 2015 06:52 PM
fcorallo
Aug 20, 2015 11:28 PM
Dialed_In
Aug 20, 2015 01:45 PM
