pulling the smog/air pump ?
Old Aug 21, 2012 | 02:02 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Hey gang, I am in the middle of swapping the old blown smog/air pump off the 91' V6 , 3.1 L and I managed to get the top and bottom bolts pulled, the plug is disconnected, but the damn thing will not come out,I can see a hose holding it tight, do I need to jack the car up to get at the hose to fully remove the smog/air pump and do I need some needle nose pliers to disconnec the hose??
Thanks in advance
Old Aug 21, 2012 | 02:34 AM
haisud's Avatar
Re: pulling the smog/air pump ?
is this mod good for better MPG?
Old Aug 21, 2012 | 03:40 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
IMO..not really. Its mainly to make the engine bay cleaner. Might net 1 MPG and 1 Hp.
Yes bud you need to get those clamps off with some pliers. The belt with no ac/ no AIR is a 81.5 i think. Its early in the morn so i may be off. But im not sure if you have air. Just tell the parts store you have a V6 camaro with no air, or no air and no A/C and they will give you the right belt.
See my engine bay its still a little messy but the AIR system, IF you dont have emmisions, can be a easy way to somewhat clean up the area.
Old Aug 21, 2012 | 02:39 PM
sheltonw3's Avatar
Engine: Classified
We are looking just to replace it, but thanks for the tip though!
I might be looking later to shorten up the Air filter tubing and just place it in front of the carburator later on down the road!
Old Aug 21, 2012 | 04:46 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Ok sorry man, Im just use to so many ppl just taking them off for no reason.
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
chazman
Aug 22, 2015 02:01 PM
spaigo
Aug 21, 2015 07:46 PM
formula_novice
Aug 18, 2015 08:48 PM
