Like a poor lost puppy it followed me home
2.8 firebird/auto 3:42 rear pleather seats /doorpanels
red on black
has a blown trans 150k on the engine , got the guy at the junkyard to swing a 9 inch tailshaft th350 in with the deal
can anyone guess what ill be doing with this? well besides saving it from the crusher
red on black
Re: Like a poor lost puppy it followed me home
clean title walked out the door with the car = 4 steel rims and tires + the good th350 trans for 250 bucks
car dosent need much the front bumper cover is just not fully bolted on ,need to see whats upwith the headlights , some slight body work.oh yeah and the inevitable dash pad
other then that it need a trans which is what the th350 is for , and i need a driveshaft as somone bought it before he thought to give me a call about the car
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Good deal, he must like you because he could have scrapped it for a lot more. Is this going to receive your V6 blower motor, or do you have another turbo build in store for this one? Funny how you went Firebird this time, as I'm now looking at a '92 3.1 Berlinetta hardtop for a grand over here lol...
i didnt want a firebird since i have another but f-bodys are hard to find out here so ill take what i can get
im either going to setup the 2.8 for boost or pick up a cheap 3.1 crank , and get new pistons and turn it into a 3.1 , port the heads, 264/272 turbo grind cam , 3.4 intake , gt3582 turbo , th350 trans with the 3:42 gears which will be mini spooled
once its done ill do the body work ship it over to macco for a 400$ paint job and use it as my new driver
oh yeah the first thing to go is the stock dash , alls it has is the 80mph speedo and a fuel level gauge , and a ton of idiot lights , have to see what it would take to do a transam/gta cluster swap
Sounds like a plan. Keep it sleeper though, w/no ground effects. Should drop a lot of jaws...
though it will be very hard to go 13.50's with up here , im at 6,500ft above sea level , and that usually goes much higher with the heat here.
the good news is all the other cars slow down as well , a 10 sec car at e-town woudl prolyl run mid 11's here
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
That car would be pretty bada$$ if it were combocharged.
i could very well do that with my other firebird, im in the middle of putting a 4-71 roots blower ontop of a 3.4 for it , wouldnt take much to add a turbo but the 4-71 blower will support more power then i can make by itself
Originally Posted by project89
thats the plan, though it will be very hard to go 13.50's with up here , im at 6,500ft above sea level , and that usually goes much higher with the heat here...
i may make this my build thread not sure yet
thinking i might play with compound turbo setup , few things i dont undertsand though is once the air has gone threw both compressors say at a moderate boost level actual boost is like 50-75 psi but only so much will show on th eboost gauge say 15psi
ill have to do mor ereasearch but from what i rember the second compressor multiplies the first compressors presure depending on what the setpoint is for boost level on each compressor
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
$250-$300 is all you get from big full frame cars in the end.
Even less if it has no title here as it has to be cut into 3 pieces also, so its not a car anymore.
Just have to find a guy who you connect and jive with and they will gladly give you lots of stuff for low cash money if they don't have to process it.
ill have to do mor ereasearch but from what i rember the second compressor multiplies the first compressors presure depending on what the setpoint is for boost level on each compressor...
Compound Boost Facts
Written by HellionCraig
Because of the overwhelming popularity of the compound boost setup, and the many questions that surround it, we at Hellion Power Systems have decided to include a Compound Boost section to specifically answer the most common questions we receive and to also get some facts out in the open about the systems and their performance.
FAQ:
Q: Can I use the System WITHOUT the Supercharger?
A: Absolutely. This kit will attach to a stock 96-98 or 99 & 01 Cobra intake just like our other 96-04 Cobra single turbo kit, or will attach to a sheet-metal intake on GT500's. The Supercharger is simply an option for those who want to try the Compound Boost setup .But no, the supercharger is NOT a requirement.
Q: Will I Make More Power With a Smaller Pulley/More Boost?
A: The short answer is no, not necessarily. In the compound boost setup, the turbos are the more efficient power adder, and because of this, we want to try and utilize the power they can make as best we can. By turning the supercharger faster than it's factory setting of 8-10 psi, the compounding ratio is increased, and therefor total boost levels will increase at a more pronounced rate. This may limit the amount of boost that we can run from the turbochargers, which may limit top-end power. However, by turning the supercharger faster, it is possible to create more low-end power and torque, at the expense of top end power efficiency.
Q: Can I use a Kenne Bell or Whipple Supercharger with the Turbos?
A: Yes. Keep in mind though, there are some precautions to take with the larger, twin screw superchargers. The amount of air that a twin screw supercharger would flow through it, as well as the manner in which the twin screw superchargers compress air will lead to much, much higher total boost levels versus a roots style supercharger. This is an important factor to keep in mind when tuning the car for maximum power. Turn the supercharger slower with a larger pulley, and any potential issues should be resolved.
Q: Is the Supercharger a Restriction?
A: No, not at all. The supercharger is not a stagnant, solid piece that air has to travel around or through. Rather, the supercharger is simply doing what it does, and that's take air and essentially make it smaller. The supercharger will simply take the air that has been compressed by the turbochargers and further compress it as it travels into the engine. In fact, the turbochargers will basically help to improve the overall efficiency of the supercharger. Roots and screw-type superchargers experience a condition known as "back flow." Back flow refers to air that doesn't make it into the engine when it is compressed, and actually comes back up into the intake tract. This air is heated, and is the cause of the loud noise heard from positive displacement superchargers. When the turbos are added in conjunction with the supercharger, they help to keep the airflow directional, minimizing the amount and effect of the back flow. Also, it's important to remember that boost itself is actually a measure of restriction, so to speak. The number that we read as "boost" is positive manifold pressure, or the byproduct of the engine only being able to flow a certain amount of air through it at any given time. The air that is being forced into the engine will eventually overcome the amount of air that the engine can ingest during every revolution, and the resulting "back up" of air is positive manifold pressure, or boost. Therefore, by using the supercharger to create a higher level of pressure, it cannot be viewed as a restriction.
Q: How Come the Turbos Alone Will Make More Peak Power at the Same Boost Level Then?
A: As previously stated, the turbochargers are the more efficient power adder (supercharger vs. turbo). In the compound setups, the turbo boost level is limited because the air will be compressed again by the supercharger. Therefor, 20psi of compounded boost will only be about 8 psi from the turbos and 8-9 psi from the supercharger. This means that you will see peak power characteristics that reflect the amount of turbo boost present, with low-end power characteristics of a supercharger. The total boost number is somewhat irrelevant. If we use the turbos only to create 20psi, they are in a more efficient airflow range, but will lack the low-end power of the supercharger. Also, the turbo combinations with lack the mechanical losses, however minimal they may be, which will lead to slightly higher peak power numbers.
Q: What are the Real Benefits of the Compound Boost Setup?
A: The real world benefit of a compound boost setup is average power and driveability. With the compound setup, you can still have the instant boost and low-end grunt of a supercharger, but the addition of the turbochargers will allow for a much more efficient and powerful top-end. This is referred to as "power under the curve." The average amount of power that we are able to produce with the compound systems will provide better driveability while still producing hair-raising amounts of power. Here's a quick example of how to think about it:
Let's say that we have a car that makes 1,000 hp peak, but only makes 500 - 1,000 hp for around 3,000 rpm. Now, we have another car that makes 900 hp peak, but makes 500-900 hp for 5,000 rpm. If we use a linear progression of power to calculate the average power through 5,000 RPM, the second car in question would have an average power output of about 700 hp through 5,000 rpm, whereas the first car mentioned would only have an average output of about 550 - 600 hp through 5,000 rpm. Using this equation, the first car in question has a higher peak power output, however the second car will most likely out-accelerate it due to the fact that it makes more average power over the same RPM range...
http://www.hellionpowersystems.com/i...boost-resource
Originally Posted by Gumby
Not if you include labor for the prep...
same concept but im talking about doing it with 2 turbos im sur eits still the same though
same concept but im talking about doing it with 2 turbos im sur eits still the same though...
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Engine: LZ9????
Transmission: 2004R
Nice Fiero! Is this the one that's getting the turbo in the other thread...?
Engine: LZ9????
Transmission: 2004R
oh no way, just a fixer upper that gets better fuel milage than the mustang lol. cant find much in vegas
sorry to jack your thread dave
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Everyone is getting these new toys but me
Nice dave. Turbo that puppy.
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Don't feel bad fasteddi. I don't even have enough money right now to work on the toys I got, let alone get a new toy. We'll be miserable together. LOL!
As always, I love seeing new projects. Excited to see where this goes...
Me thinks it's about time to get a little challenge going. Perhaps a 2.8/3.1/3.4 challenge. Let's say we have the entire winter to work on a project, any project, build it however we want, but it's got to be a 2.8/3.1/3.4 of course, and the first one to hit the tens, wins. Anyone game...?
Engine: LSJ
Axle/Gears: 4.05
Would LOOOOOVVVVEEE to see this grudge-match!
Car: 1991 Camaro RS
Im down Rob
Engine: LSJ
Axle/Gears: 4.05
Engine: LZ9????
Transmission: 2004R
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
wish you could come save the bird in the yard near me... 89 gta, delux gta interior, t tops, factory 350, dark magestic blue, aluminum drums and rust free.... beings parted out because the tranny went bad... i have pictures of it on my build thread..
either that or i just team up with fast or blazer and make sure one of them hits the 10's first
wow thats a shame
Originally Posted by fasteddi
Im down Rob...
that looks like an early berlinetta
that looks like an early berlinetta...
something is fishy with that car rob , no gfx for one.
id stay away from it
im going to go out on a limb and say its an early car somone is doing something fishy with the title
hell if its got a maf sensor u know its bogus
if it is an early one chances are it has the early engine which is dog poop
Look at the nose clip, see how the white is different from the fender. I'm thinking tagged. The hatch has the correct 3rd brake light in the upper glass, so the hatch is more than likely '92 as well...
ilso check the rockers for mounting holes for the gfx same with rear quarter panels
drop the ecm and check the number 302= 2.8 car
ilso check the rockers for mounting holes for the gfx same with rear quarter panels...
Car: 1991 Camaro RS
We demand updates!!! Lmao
opps i updated on the other site.
anyways this car is getting the 3.4 and blower , i have the adapter mocked up and figured out a work around for the blower drive so i could center the blower on the intake front to back.
ned to get ahold of some 1/2inch thick aluminum plate and take it over to a welding shop few towns away to get it welded up
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I'm up for the grudge match! anybody want to send about $1k my way so I can do the build?
RedLeader289
May 28, 2019 01:47 PM
3.8TransAM
Sep 27, 2015 08:37 PM
