Throttle body vac line ID please.
2.8 TB has two lines on top of it. The one on the driver side is for EGR I believe. Egr is gone. Can I cap the line? Also Can I get rid of the other line as well and cap it where it goes? The lines suck air or pull air? I know its a bit redundant, but I cant find an explanation simple enough for me to understand. Im a bit slow.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Throttle body vac line ID please.
I have posted a pic with explanations in the past... You can't delete the non-EGR line as it's for the fuel pressure regulator...
Engine: 2.7L V6
Axle/Gears: 4.41
Why would you want to? Everything connected to the TB has a purpose or it wouldn't be connected there. And yes, the TB port is the closest manifold vacuum port for the FPR.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
