No check engine Light
Old Oct 20, 2012 | 01:01 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
I have searched for a quite a bit on here and google and I havent found anything to help me fix the check engine light. I want to set the timing with a timing light and I know you have to put it into bypass mode where the check engine light flashes randomly and the rpm goes to base timing but I cant seem to get the check engine light to come on. We checked the bulb already and it still wont come on. Any suggestions would be nice.
Old Oct 20, 2012 | 05:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: No check engine Light
Well, first, put a wire in the diagnostic connector as though you're pulling codes and make sure the ECM CAN turn the light on in the first place.
Old Oct 20, 2012 | 09:03 PM
ex-x-fire's Avatar
Cel should come on when you turn on the key for a few seconds.
Get a wiring diagram & do a continuity check between the cel socket & the other end (ecm & ground) of the circuit.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
