*NEED SOME HELP* valve adjustments 3.1
Old Nov 5, 2012 | 08:16 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
ok i got 88 with 91 3.1..replaced head gaskets and rods and new hydro lifters and having trouble adjusting valves..after 0 lash.. is it 1/2 3/4 or 1 1/2 turns?? one manuel says 3/4 and all data manuel says 1 1/2 ? i did 3/4 and it sounded loose when u get on it like a rattle?! and 1 1/2 felt to tight like made my motor jerk and shake and wont go past 75 mph...whats wrong here? i also had a low oil reading changed the pump and 2 sensors on the block and still reads a quarter insted of 40 (even) ? gauge bad?
thanks for input or help
Old Nov 5, 2012 | 08:29 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: *NEED SOME HELP* valve adjustments 3.1
i just did head gaskets on my brothers 90 3.1L last week lol. and i went by the book and did 3/4 turn after 0 lash (wasnt very easy to figure when i had 0 lash), so it wasnt very cut and dry for me, seemed to be a gray area....but after first run around town for an hour or so, everything seem great. well today i actually just went out to move his car out of the way, and now its got a very loud tap. so i dont know when im going to get back around to his car to tear back into it. so i think either a lifter may have collapsed after shut down last week
Last edited by cIaRmOaCrZo; Nov 6, 2012 at 07:16 AM. Reason: too over someones head
Old Nov 5, 2012 | 09:16 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
get the valve to be closed. Then twist the pushrod and tighten the nut at the same time untill it just barly moves(zero lash). Then tighten a additional 1/2-5/8 turn. (my book says 3/4 but thats too much in my mind) I alwasy turn mine 1/2 turn extra after zero lash and have done that on many occations and never had loose lifters. But my zero lash may be different then someone elses.
Once you do all the rockers make sure to go back over them one by one and adjust a hair if needed. Keep in mind that if there over tightened that can cause some problems.
I see your sig says turboe V6 in ohio??????
Old Nov 5, 2012 | 09:18 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by cIaRmOaCrZo
.......... or a lobe wore off the cam after shut down last week
Um , , , Dude ? , , I ain't no physics major . Nor a rocket scientist . Not even much of a heavy thinker ........
BUT !!!!
Even I know that NO damn cam lobes went wearin off WITH THE ENGINE STOPPED !!!!!
I'm not lookin to mess with ya here , but that explaination just sounded SO out there , , , there is no mechanical wear happening in a not rotating engine . Period . Now , the lobe coulda wore down while the engine WAS running , and the tap wasn't noticed till the next cold start , sure , i"ll buy that . But if ya ever have the lobes wearin off of a stopped engine's cam , ya'll need an Exorcist and not a mechanic , cause yer engine's done gone and got itself haunted
Old Nov 5, 2012 | 09:42 PM
8928cam's Avatar
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
yeah..my internals are fine lol but when i redo them ill totally run a comp check on cylinders too..but ok so a little more than 1/2 then? 5/8 ok ill try that 3/4 does seem to much exspecially 1 1/2 lol i could see new valve tran or sumthin. ill figure this out..
yah i ran 2 stock skyline turbos g reddys i got from ebay for $300 and the cooler the one turbo ball bearing is fukd up right now tryin to find a new one but no luck just yet but it just went so its runnin twin i havnt timed it yet like on track or anything bc its got some tinkers left i got alot of extras..the 3.1 is bored too 30 over smaller comp cam ive beeen slowly doin it since 2005
Old Nov 6, 2012 | 06:19 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Pics/Videos??
Old Nov 6, 2012 | 07:13 AM
Engine: 383 hsr
BUT !!!!
no ****??? damn i thought i knew what i was talking about for second lol. c'mon now, obviously its not going to do a whole lot of anything sitting still. i was talking more along the lines of an over adjusted rocker arm lifter (not enough to hang a valve open) but enough to bottom lifter out and wear the CAM LOBE during the hour long test DRIVE, and while that could be happening the lifter would just pump up with oil during the drive to compensate for the wear. then shut it down, oil bleeds out, now lifter couldnt pump back up on next start up cold, hence leaving the loud tapping noise from excessive clearance made....idk it was a small suggestion when i originaly typed that without putting a ton of thought into it.
Old Nov 6, 2012 | 06:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
1. ALLData is mostly wrong (actually, incomplete in most respects), IMHO. Although, they use the factory book a good portion of the time, and the factory book is for NEW lifters that are EMPTY of oil.
2. CLEAN OFF THE PUSHRODS BEFORE ATTEMPTING TO SET VALVES. You can't get a good grip on the pushrods to feel when zero lash has been obtained with grimy rods.
3. Contrary to what a lot of the books say, the lash is checked by VERTICAL PLAY, not spinning the rods.
4. I generally use zero lash plus 5/8 turn. I used to do 1/2 turn, but either that wasn't enough or my rocker nuts came loose after a while.
I still think it's rather dumb that our engines go by number of turns past zero play instead of the way the 4-bangers do it, torque on the nut.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
