throttle body rubber adaptor help.
Old Dec 29, 2012 | 06:20 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
im trying to get rid of the ribbed hose from my 2.8 and im having trouble finding the correct size to mount a 3inch pvc (3.5in including wall thickness) to my throttle body.
if i take a 3.5 inch to 3 inch reducer would that work? 3 inch being used on the throttle body side or will that keep slipping off? i was looking into this but id rather be sure before i buy it..
http://www.ebay.com/itm/3-to-3-5-Inc...b3e0cb&vxp=mtr
thanks guys - Aaron
searched it and couldnt find anything to the diameter to use on the TB side..
Old Dec 29, 2012 | 06:50 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: throttle body rubber adaptor help.
This one is down from 3inch off the tb to 2 1/2 pipe for my charge piping.
Believe me if you clamp it well it will never slip off. Ive ran up to 18psi or so and never had it blow off.
PVC is tricky though as if you have high engine bay temps that stuff may not always bold up right, but im not sure to be honest.
Old Dec 30, 2012 | 12:34 AM
Mailman818's Avatar
Engine: 2.8L V6
Cool ill order ir then it
The pvc has help up really well. And it doesnt really get too hot since the routing is not in the engine bay and i guess it stays pretty cool. Eventually when i get my turbo build finally going(need spare car, learn to weld, and buy my tuning software and training on that) ill swap to the other piping
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
