idle increase while in netural and moving
Old Jan 27, 2013 | 08:20 PM
Twessing's Avatar
Car: 92 Chevy Camaro RS
Engine: 3.1L V6
So i was driving home tonight and i put my car in neutral while coasting down a hill and my idle slowly came down then quick jumped up and held there. When i put it back in drive it leveled out to normal and i kept driving. So i came to another hill and i left it in drive but let off the gas and coasted and it did the same thing but the RPMs didnt raise as high. Im completely confused
Thanks!
Old Jan 28, 2013 | 06:08 PM
Twessing's Avatar
Engine: 3.1L V6
Re: idle increase while in netural and moving
Anybody?
Old Jan 28, 2013 | 06:41 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
how high did the rpms rise when you were coasting and put it into neutral?
Old Jan 28, 2013 | 06:45 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Also does the car run weird else then that?? IIRC thats not that abnormal if were saying it went up to like 2k rpms or so then dropped if you were costing down the highway.
Old Jan 28, 2013 | 06:47 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
on that question.
Sounds like the IACV is doing it's job, pending on how high the RPM's went.
Old Jan 28, 2013 | 06:52 PM
Twessing's Avatar
Engine: 3.1L V6
Well my tack doesnt read properly but according to it, it went from 1500 while coasting in neutral up to about 2500 or so and held until placed in drive
Old Jan 28, 2013 | 06:53 PM
Twessing's Avatar
Engine: 3.1L V6
the car also runs fine otherwise
Old Jan 28, 2013 | 07:49 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Have you cleaned your idle return spring on your Throttlebody to ensure it isn't stiff or sticking?
Old Jan 29, 2013 | 08:21 AM
Twessing's Avatar
Engine: 3.1L V6
Where might this spring be located on the throttle body?
Old Jan 29, 2013 | 08:26 AM
Twessing's Avatar
Engine: 3.1L V6
I dont think there is a spring at all, but two cables going to the TB. one is the throttle and the other idk
83 Crossfire TA
Jan 3, 2016 01:26 PM
bamaboy0323
Sep 3, 2015 06:07 AM
IROCtometal
Sep 2, 2015 02:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
