Oil pressure high
Old Mar 22, 2013 | 12:03 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Oil pressure high
My oil pressure has been really high since I gave it an oil change two weeks ago, the gauge reads above 80 and it also idles rough until it goes down a little. It idled rough before due to a vacuum leak (which I have yet to find) any reason why? Is this bad?
Old Mar 22, 2013 | 12:06 PM
project89's Avatar
Re: Oil pressure high
unless u put something like 90-120 wieght oil in it tthe oil presure isnt really that high
prolly a bad sending unit or gauge
the only other way i could se eit actually being that high is if the oil filter is pluged up or an oil passage in the block is plugged up but that is highly unlikley
Old Mar 22, 2013 | 12:09 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Okay, I have a few bad sensors, like EGR and MAP sensor, where is the oil pressure sensor located?
Old Mar 22, 2013 | 02:06 PM
project89's Avatar
driver side right above the oil filter
Old Mar 22, 2013 | 02:33 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
try disconnecting the battery then the sensor. reconnect sensor then battery. I had the same thing happen a while back. disconnecting the sensor seemed to fix the problem.
Old Mar 23, 2013 | 05:01 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
I will try that, thanks
Old Mar 25, 2013 | 08:43 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
The oil gauge in my RS 3.1 always reads high like that, but even when the car is off it does not rest all the way down so I know my gauge is mesed up. I'm with the other guys, I think the sensor/sender is bad.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
