2.8L V6 ISSUE
Old Apr 7, 2013 | 02:19 PM
l0stpuppy's Avatar
Car: 1986 Firebird
Engine: V6 2.8L
Transmission: Automatic
2.8L V6 ISSUE
So, I have a 1996 Firebird, with a current issue, that I can not trace. I have done the paperclip trick, and its not sending off a code worth worrying on, besides 12. I can be driving down the road, and as I'm driving, the engine will start to sputter, the radio will cut in and out, the sub will still play but yeah its rather off tone at this point, and then it'll all come back, and act normal. The engine light will flash on and off. I have replaced the Ignition Control Module, I have had the alternator checked at 2 different shops, along with the battery and all cabling. It is all good. What else can it be?
Old Apr 7, 2013 | 02:41 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: 2.8L V6 ISSUE
Originally Posted by l0stpuppy
...and all cabling. It is all good.
Can you be more specific?
How do you know its "good?"
I think you have a poor connection in your ignition, or what may also called a "bad ground."
Check all connections to the coil and the distributor.
Make sure your batter connections are all clean and tight.
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2.8L V6 ISSUE
is the steering all lose n sloppy? GM never use locktite on the tilt bolts, they come lose with time, its slop can F with the ign switch,[not one the key goes in, that one just pushes a rod for the real switch under dash] when mine was sloppy, backing up to the left would turn the car off on me.
Old Apr 7, 2013 | 03:43 PM
l0stpuppy's Avatar
Car: 1986 Firebird
Engine: V6 2.8L
Re: 2.8L V6 ISSUE
I have yet to have it happen when I'm actually turning, normally happens when I'm going down the road, I mean i can have the car not acting up to having it lose power, bog down, chugging, and the radio literally quit playing to then it being totally okay. I have had the lights flickering as well during this, going from normal to dim like flashing but rapidly.
Old Apr 7, 2013 | 04:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2.8L V6 ISSUE
check bulk head for main wiring harness.
Old Apr 8, 2013 | 05:50 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Re: 2.8L V6 ISSUE
Sounds like a bad wire somewhere.
Possibly a bad ground.
Old Apr 20, 2013 | 07:46 PM
l0stpuppy's Avatar
Car: 1986 Firebird
Engine: V6 2.8L
Re: 2.8L V6 ISSUE
So, replaced the iginition coil, checked out the sound system (removed it included) still had issues, i get up to 40mph or just past there then start having a ton of issues. The pump, and the injectors were put in, back in 2011. Help please?
Old Apr 20, 2013 | 07:47 PM
l0stpuppy's Avatar
Car: 1986 Firebird
Engine: V6 2.8L
Re: 2.8L V6 ISSUE
oh and i'm close to losing my mind on this one..... so very close......, with the backing up issue, its when i start to back straight up, and not ever time.
Old Apr 22, 2013 | 05:44 PM
Engine: 3.1 v6
Re: 2.8L V6 ISSUE
Classic bad ground scenario.
Old May 10, 2013 | 08:22 PM
l0stpuppy's Avatar
Car: 1986 Firebird
Engine: V6 2.8L
Re: 2.8L V6 ISSUE
Voltage Regulator, inside the alternator. Problem Fixed.
Old May 10, 2013 | 08:30 PM
l0stpuppy's Avatar
Car: 1986 Firebird
Engine: V6 2.8L
Re: 2.8L V6 ISSUE
I thank ya'll for the help. I thought bad ground as well, but ran out of ideas after that 0_0. Started tracking it down, and came across what a voltage regulator will cause.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
nd4spd42085
Nov 23, 2008 01:00 AM
dcm01003
Aug 18, 2006 01:55 AM
