Battery removal problem!
Old Apr 12, 2013 | 06:53 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I tried channel locks, they are no good, so whats another method for getting a bolt off of a side post battery, i already got the positive line off, but the negiative seems like its seized up!
Old Apr 12, 2013 | 06:54 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Use a socket and ratchet. Channel locks are just going to strip the bolt. Never use them on battery terminals.
Posted from Thirdgen.org App for Android
Old Apr 12, 2013 | 07:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Battery removal problem!
And always take the negative cable off first. Don't even go near the positive cable bolt until then. Short that positive bolt to the chassis with the negative cable still connected and a lot of bad things will happen.
RBob.
Old Apr 12, 2013 | 07:09 PM
mcrandrz's Avatar
Car: 1991 camaro rs
I just checked my battery. Its an 8mm socket. it should come right out.
Old Apr 12, 2013 | 07:37 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Take off the ground first, always do that. Rbob is dead on with that!
It's a 8 mm like he said but if she don't come off and is already stripped pretty bad then vice grips are the last alternative. Try a little wd 40 before it comes to the vice grip point if you can.
Old Apr 12, 2013 | 07:42 PM
OrangeBird's Avatar
Car: 1989 Firebird
Last edited by OrangeBird; Apr 12, 2013 at 07:43 PM. Reason: Fast Eddie beat me to the vise grip suggestion :)
Old Apr 12, 2013 | 08:30 PM
sheltonw3's Avatar
Engine: Classified
Vice grips are not makng the grade here, Already WD-40'd it, tried taking the neg off first, the bolt is stripped!
So where on the 3.1 liter engine is the negative connected too?...I may have to just pull the cable from the other end to swap everything out?
Old Apr 12, 2013 | 08:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
First, the bolt is a 5/16" hex... They make wrenches specifically for GM side post terminals.
Second, the negative cable goes to the engine block to the power steering pump side of the crank pulley. 15mm bolt, IIRC.
Old Apr 12, 2013 | 09:17 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
5/16" and 8mm are the same size, a couple thousands of an inch difference if you want to get real technical.
The "Specific" wrenches are just because MAC and Snap-On can, and mechanics will "have to have them".
Old Apr 12, 2013 | 09:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Um, if they're different sizes, they're different sizes. Couple thousandths or not. And I believe an 8mm was loose on my batt terminal bolts the last time I tried...
And the specific wrenches are just that... I have one for a reason, because it's pretty tight where the battery is. And it's not MAC or CrapOn.
Old Apr 12, 2013 | 09:36 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Mine is 5/16" and its a specialty Craftsman ratchet made for battery bolts but it sounds like you're way past that. Now are you just trying to take a bad battery out of the car or are you saving it or what? To get the bolt out get a set of vice grips with flat not curved jaws and get the on as tight as you possibly can. If they slip they are not tight enough. Tap the bolt head lightly a few times and try to remove it. Make sure that you are turning it in the right direction (i.e Lefty- Loosey) and it should come out. It sounds like it may have been cross threaded in and the battery may not be able to be tapped and re-used. Good Luck!
Old Apr 12, 2013 | 09:52 PM
shadetree411's Avatar
Car: 1989 Camaro RS T-Tops
Engine: v6 2.8
Transmission: auto
If battery is trash, die grinder and a cutting wheel just be careful of the cable.
Old Apr 12, 2013 | 10:00 PM
sheltonw3's Avatar
Engine: Classified
The Battery is a goner, but it is under Warranty, so I'll wait until day light to see if I can get it out?
Old Apr 13, 2013 | 06:34 AM
fasteddi's Avatar
Car: 1991 Camaro RS
8mm and 5/16th are so close that Ive always used 8mm on the bat cable along with my hose clamps on the car. Since almost everything else on the car is metric..lol
The neg wire on the car is mounted right to the front drivers side of the engine block. I believe that is the main wire. Then there are multiple wires that go off the rear of the heads(both of them) to ground electonics such as the ecm....exc.
Old Apr 13, 2013 | 08:40 AM
mcrandrz's Avatar
Car: 1991 camaro rs
If the battery is under warranty then take it to where you got it and have them do it lol
Old Apr 13, 2013 | 08:54 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
If you already use dvicegrips on the bolt, and they didnt work it may be time to cut off the old crappy terminal and replace it with a new one... I've had to do this a hundred times...
Old Apr 14, 2013 | 01:30 AM
Richboll's Avatar
Engine: 305 TBI
So fill us in...what happened?
Old Apr 14, 2013 | 05:01 AM
sheltonw3's Avatar
Engine: Classified
I got the battery out, the bolt was 19mm, I just unbolted the ground from the engine & frame and it all come out easy then we took the old battery down and one of the guys was able to Turbo wrench off the negative cable so that saved me a few bucks, we got our warranty honored and off we went to Autozone to quickly grab a new EGR valve controller, and some fresh motor oil, we returned to home, then in 45 minutes later the cable was reconnected and the EGR was replaced and the runs smoother than ever, I still have to get new front brake calipers on Sunday and waiut for the weather to give us a break from the rain to get the car road ready!
Old Apr 14, 2013 | 11:41 AM
Richboll's Avatar
Engine: 305 TBI
Congratulations! What's a Turbo wrench?
Old Apr 15, 2013 | 09:18 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Probably an air ratchet lol
Old Apr 15, 2013 | 11:05 PM
Richboll's Avatar
Engine: 305 TBI
That's the only reference I could find for "Turbo wrench". But if so, how did they get a grip on the battery bolt? Sounds like somebody didn't eat their Wheaties.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
3rdgenparts
Aug 8, 2015 07:09 PM
