Alternator relocation.
Old Jun 10, 2013 | 09:21 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
So I've been reading around and I figure since ill be down there removing the smog pump. Is there a way to put the alternator in its place? I just think it will clean up things alot and will make top end work less of a pain.
Posted from Thirdgen.org App for Android
Old Jun 10, 2013 | 10:07 PM
Fordvette's Avatar
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
Re: Alternator relocation.
Im not sure, I think I found the Fiero 2.8 for my engine.. Dripped them low and kept it clean
Old Jun 10, 2013 | 10:56 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Back when I built my Franken60, I did just that, I moved the alternator down to where the A.I.R. Pump would have been.
I shortened the actual bracket to fit better than using spacers, and made a custom upper bracket that also supported the tensioner.
Old Jun 11, 2013 | 06:47 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
That's pretty sick bro.
Now I wanna do that with mine.
Old Jun 11, 2013 | 07:09 AM
mcrandrz's Avatar
Car: 1991 camaro rs
IMAGE#1
IMAGE#2
If I put it down do I ( or should I) support the tensioner
Old Jun 16, 2013 | 08:43 AM
mcrandrz's Avatar
Car: 1991 camaro rs
IMAGE#1
I'm just saying. Thats one ****ing beautiful engine. Thank you for the advice. I'm sure its going to take some fabrication regardless.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
