2.8 V6 Y pipe replacement
Old Jun 26, 2013 | 09:14 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I am looking for a Y pipe for an 82 Firebird 2.8L V6. I found the the below link to Summit Racing of a Y pipe for an 85 V6. I can't see how there would be much difference between the 82 Y pipe and that for an 85. Does anyone know if there is a difference between the V6 Y pipes through the years.
http://www.summitracing.com/parts/wlk-40442/
Old Jun 26, 2013 | 12:50 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 V6 Y pipe replacement
Get the 85 pipe. I had bought one off of an 84 or something years ago and found out 2 things:
1. Early pipes were smaller diameter. They also use different donut (manifold flange) gaskets.
2. Early pipes don't have the provision for the oxygen sensor. You will need to plug this (they have plugs for them) if you don't have one.
Old Jun 27, 2013 | 07:06 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Thanks for that. I had found a Walker 40446 pipe from discountautoparts and ordered it but now they tell me it is out of stock. I will try and order the 40442 pipe. I think they have it at Rockauto.
Thanks.
Old Jun 27, 2013 | 07:23 AM
midias's Avatar
Thanks.
There are a bunch on ebay but I dont know if they ship international.
Old Jun 27, 2013 | 04:06 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Keep in mind that if you do get the larger diameter MPFI pipe, you will also need to use the Walker 31550 (I believe that's the P/N) donut gaskets. Your existing gaskets, or similar, for the carb V6, are too small.
I may have posted a pic of the differences between the old and new donuts somewhere...
Old Jun 28, 2013 | 08:42 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Don't pacesetter headers come with the y pipe? Upgrade bro.
Cleotiz
Jan 6, 2018 08:56 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Springster
Sep 13, 2015 01:38 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
86Base
Aug 8, 2015 01:34 PM
