91 3.1 plenum options
Old Oct 22, 2013 | 11:14 PM
Jordon Nutbrown's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
was wanting to find out if there were any after market plenums for the v6? Mine is filthy as hell and the top corner where the bolt for the throttle body goes is cracked. Patched it with some rtv but want to get it replaced ASAP not sure if there is anywhere i can buy a new one or if my only option is a yard. Any help would be appreciated and thanks in advance.
Old Oct 24, 2013 | 07:27 PM
'86 Sport Coupe's Avatar
Car: 1986 Camaro Sport Coupe (Part Out)
Engine: 2.8 MPFI V6
Transmission: 700R4 Automatic 4 speed
Axle/Gears: 3.42 Open With Drum Brakes
Re: 91 3.1 plenum options
I think Edelbrock made one for a while. Not sure if they still make it though. I have one of a 1986 2.8 V6. Run a search and see what you can dig up. If nothing else then you now know a guy that will sell you one.
Old Oct 25, 2013 | 05:08 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
For your 3.1L you really don't have any aftermarket options. If its just filthy you can just clean it up. Aluminum is pretty easy to clean. If you want it to look really nice you can clean off the casting of the aluminum and then polish it smooth with heavy to very light grit sand paper. I did that to mine and topped it off with primer, base, and clear coat. I think it looks nice.
There's even a few members that have polished them to be shiny(polished aluminum) I just didn't have the time and patients for that, so mine became painted.
Old Oct 25, 2013 | 07:10 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
yep!
Old Oct 25, 2013 | 09:05 AM
Engine: 2.8 MPFI V6
Originally Posted by 58mark
yep!
That. Looks. Amazing!
Old Oct 25, 2013 | 09:13 AM
58mark's Avatar
Thanks!
Old Oct 25, 2013 | 09:18 AM
Engine: 2.8 MPFI V6
Your welcome. Can you tell me what that bracket is that is coming off the drivers side? Mine has the one for the alternator on the passengers side.
Old Oct 25, 2013 | 09:35 AM
58mark's Avatar
It's for the AC compressor.
Old Oct 25, 2013 | 09:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Mag wheel cleaner from the auto store is helpful in cleaning aluminum parts. Read the label and make sure it has phosphoric acid along with 'other' organic acids.
RBob.
Old Oct 25, 2013 | 09:48 AM
Engine: 2.8 MPFI V6
Ahhh ok. The one in my car is different.
Old Oct 25, 2013 | 11:14 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Wait until you try to do it. I've been polishing an aluminum rocker cover and by the time I'm done I'll have one polished and one not because I don't want to have to do it all again! My fingers are too old for that much polishing.
Old Oct 25, 2013 | 01:32 PM
project89's Avatar
if u can weld lookup the pizza box intake , i should have enough pics posted u can build ur own
its worth 30 hp , and an extra 600-900 in rpm range
Old Oct 25, 2013 | 04:37 PM
58mark's Avatar
it's not an easy job by any stretch of the imagination.. here's the thread
https://www.thirdgen.org/forums/v6/5...ppearance.html
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
toronto formula
19
Oct 6, 2015 12:27 PM
