3800 supercharger on 3.1
Car: 1986 camaro iroc z
Axle/Gears: stock
ok theres a buick with a 3800 supercharged motor at the junk yard and i was wondering could i just take it off and bolt it on my engine or do i need other things. and how much power will it add sorry if this is saposed to be in power adders
Axle/Gears: stock
Re: 3800 supercharger on 3.1
so what all do i need i mean i want to take it off the top of that engine and put it on top of mine what other parts do i need to get the best out of it
Transmission: 5-speed/T-5
Ummm, it will not fit, directly, completely custom.
I'm not sure if Kingsobieski is not paying attention or just trying to be a dick, but the 3800 and the 3.1 are very different engine families.
Do a search in this forum for similar posts and you will see some ideas of using a 3800 SC on a 2.8/3.1.
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Six shooters right, there would be alot of custom fab to make it work. And it will most definitly not add a easy 200Hp.
This is not the solution you're looking for.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
bl85c is selling a complete bolt on turbo kit. Search the v6 forum for 'turbo kit' you should find it. Probably your shortest cheapest way to get there from here.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: stock
yes i got the brakes fixed shes is all ready for inspection and tagging . do admit she needs plugs and some sea foam but shes all ready to go.
Elephantismo
Feb 13, 2019 12:51 AM
darwinprice
17
Oct 11, 2015 11:51 PM
1992, 31, 3800, bolt, camaro, fitted, kit, l26, make, sfi, supercharged, supercharger, superchargers, turbo, v6
