View Poll Results: 190 ?
170
25.00%
180
75.00%
Voters: 8. You may not vote on this poll
Est. HP ? 3.4 v6 out of a 1995 port polish heads new pistons bore hone with 2.5 exhau
Old Dec 5, 2013 | 07:11 AM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
3.4 L
3.4 injectors South Bay
Est. HP ????? I'm thinking 175 easy
3.4 v6
out of a 1995
port polish heads
new pistons everything gone through
bore hone with 2.5 exhaust
And moates tune chip custom burn. By: (Fasteddi )
It's waiting to be installed in my current 3.1
Pics coming soon.
Old Dec 5, 2013 | 10:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Est. HP ? 3.4 v6 out of a 1995 port polish heads new pistons bore hone with 2.5 e
HP at the wheels or crank? Are you running the stock cam, exhaust manifolds, etc? Factory compression? No offense on this part, but are the heads being ported by someone who knows how to properly port heads? You can lose a lot if its not done right.
Old Dec 5, 2013 | 12:01 PM
OrangeBird's Avatar
Car: 1989 Firebird
To The OP , Thank You for the edit , and I have voted on your poll
Old Dec 6, 2013 | 02:36 AM
KG427KG427's Avatar
Car: 1991 camaro
Machine shop is supplying the new cam, and they know how to port and polish. exhaust was upgraded to 2.5 pipe dyno max, posi 9 bolt 3.27 gear
Dual snorkel k and y cai
Old Dec 6, 2013 | 05:53 AM
drdave88's Avatar
Engine: 6.0L
Originally Posted by init4fun
The name of the Injector place is " SOUTH BAY " .......
Either your " south pay " is a typo , in which case you REALLY should change it , or it's a lame cheesy attempt to be funny , , that REALLY isn't .
Your next move here will indicate which it is , and untill it's corrected , I'd urge all of the TGO members to stand with SB on this and refuse to participate in this thread .......
Wow, do you own the company or something? It was a typo, relax a bit. No need to start a petition or picket outside the guys house.
Back to topic, I would think you could get close to 200 at the crank, maybe over with the proper tune. Only way to know for sure would be dyno, but that's my .02.
Old Dec 6, 2013 | 06:06 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Be sure that the shop doesnt grind away the shark fin on the intake ports. Make sure they work the valve guides as those are horrid in the stock form. If the shop falls though im tying to sell my iron ported polishes deshrouded heads. Im doing a hybrid conversion.
Old Dec 6, 2013 | 07:38 AM
project89's Avatar
i would sell him yours , 100 bucks says the shop screws up his heads
i know ur heads are close to perfect just from the power they made, only took 3 more psi then it did with mine to run the same times
Old Dec 6, 2013 | 08:06 AM
OrangeBird's Avatar
Car: 1989 Firebird
No Sir , I do not own the company . I DO own some of the company's fine injectors though , and with the dedication I see the SB guy put into helping folks on this forum , I wasn't gonna stand by and watch his name be slammed by either typo or other intent . Yes , it obviously was just a typo , and the OP fixed it . end of story .
Old Dec 6, 2013 | 03:17 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Well mine are def. for sale. OP message me if interested. But if your still going to a shop just make sure they know the specifics on a gen 1 60* head. Mainly where to not take material off.
Old Dec 7, 2013 | 01:24 AM
KG427KG427's Avatar
Car: 1991 camaro
Fasteddi I need you to burn me a 3.4 chip
I haven't set up the cable yet.
Old Dec 7, 2013 | 06:52 AM
fasteddi's Avatar
Car: 1991 Camaro RS
pm me but I really need to see the data logs from the car. Get the cable hooked up if ya can.
Old Dec 10, 2013 | 08:03 PM
KG427KG427's Avatar
Car: 1991 camaro
pm sent.
link me to that ALDL? cable, I will buy that so I can get that hooked up to my car asap and get some datalog for you for the tune.
you have any other v6 parts like relays.
Another issue came up. Every time I wash my car. Their is some leak because on the floor on the driver side, it gets completely wet. how on earth am I going to find and fix that kind of leak?
Old Dec 10, 2013 | 09:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Take off the lower underdash panel... Money says there's a slit in the bottom of the cowl up against the bulkhead. You may need to pull away some insulation to see the hole(s).
Old Dec 22, 2013 | 10:37 AM
firstfirebird's Avatar
I dyno'd a .030" over rebuilt 3.4 only made 122.4whp but an impressive 153wtq...
Old Mar 25, 2014 | 04:11 PM
KG427KG427's Avatar
Car: 1991 camaro
your heads were cracked. thanks. maybe a refund or can u send me a throttle bottle for a v6 or something in return ?
thanks or a 3.4 v6 chip burned would be nice ...
Old Mar 25, 2014 | 04:14 PM
KG427KG427's Avatar
Car: 1991 camaro
project they were cracked lost about 300$ plus I have to buy another set lol
Old Mar 25, 2014 | 04:20 PM
fasteddi's Avatar
Car: 1991 Camaro RS
This sort of topic is for PM's. You didn't pm me back but you posted this instead??? You wounder why we cant work something out.........
92projectcamaro
Aug 6, 2015 01:20 PM
89 Iroc Z
Dec 2, 2001 07:14 PM
UVA3rdGen
Jun 20, 2001 08:17 AM
bub
Feb 26, 2001 09:52 AM
