What could have caused this
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Consider that the engine never overheated and never rose above 190* tops. What could have caused this crack. The buyer of my heads just sent me this pic of my old head and look at that crack!!! Ran fine on my car and i didnt see it when i took them off but might have over looked it?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What could have caused this
It may have been there for along time but you never magna fluxed it for it to be evident.
excessive heat is what does that , unless its from mechanical damage , on the other hand i do find it hard to belive it managed to crack between the seats
my 2 guesses are going to be thats the cyl that detonated and broke the piston or...
u had excessive backpresure and lots of heat buildup in the ex port
Car: 1991 Camaro RS
Was the number 2 or 1 cylinder. It could have been there a while I suppose. The detination that took out the piston in 2012 was number 6 cylinder
have the head presure tested if it dont leak tell him to run it
Car: 1991 Camaro RS
hes got it at a machine shop. i think hes ditching the heads all together.
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Car: 1991 Camaro RS
There in cali. They may be closer to you dave. I guy on here got them off me. Im sure he would give them to ya as hell probly be tossing them in the trash. It cost 150-200 bucks to ship them to cali from where i live.
I got a spare set of irons but there stock.
holy crap thats alot , blazer u still down in las vegas ?? ill be heading down to the track sometime in feb with the iroc talked my buddy into towing the car down with his diesel truck instead of my silverado , should save a ton on fuel costs , or atleast i hope it will
Engine: LZ9????
Transmission: 2004R
Engine: LZ9????
Transmission: 2004R
Free for the heads, had a valve job done on them and maybe put 6-7K miles on them. Been sitting since 2006 lol. Oh and they are missing a couple of valves, when I ported my other set I used those to protect the seats.
Depends when you want to run, for their midnight of mayhem they don't do any prep. no water box either due to every r.icer thinks they can do a burnout, and then blow the trans. Slicks for sure. Elevation at Nellis is ~1900ft, and its 1/2 mile from LVMS.
it prolly wont be a midnight then , as if u saw my build im shooting for 1000hp , and if the track aint preped i might as well make some runs on the street and save the 200 bucks or so in fuel it would cost to tow the car down
prolly have to go for a test and tune to make sure there is good prep , will be first outing for the car so ill prolly make a launch , then a halftrack pass and then full pass if all checks out
need to find out about getting the cage certified , and getting my comp license while im down there as well ,,, lmao i dont even know what nhra division im in
Engine: LZ9????
Transmission: 2004R
1900 ft sounds so much better then my 6500 ft lol and free is always a good price thanks
iirc my car setup is only good for 10.00 and slower ( tech wise) , dont mean i wont set it on kill and make a full pass anyway , i need to get the conversion kit to change it into a full cage to run faster
also have to pick up a gopro before i come down
HoosierinWA
Oct 7, 2015 10:15 AM
