EGR to manifold gasket?
Old Mar 18, 2014 | 09:26 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
When I changed my EGR recently I also changed the tube that extends the EGR to connect it with the Manifold on the Passenger side. I don't remember there being a gasket that connects the two, and the assembly manual doesn't show a gasket, so I just left it metal on metal down there
well, now my engine is noisier, and I can tell when I did sea foam yesterday I have a considerable leak coming from the base of that tube. I've thought about adding a gasket to seal things of, but I don't know what kind I need because it's not a factory part.
there's this one, which looks correct.. it's for a 93-95 3.4 camaro. It's an EGR gasket, but I'm not sure what part of the EGR, and don't know if it comes in direct contact with the Manifold. How can I tell if it will stand up t the heat generated?
Fel-Pro 70798 Gasket : Amazon.com : Automotive Fel-Pro 70798 Gasket : Amazon.com : Automotive
Would I be better off making a gasket out of something like this?
Mr. Gasket 5961 Ultra Seal Exhaust Gasket Material : Amazon.com : Automotive Mr. Gasket 5961 Ultra Seal Exhaust Gasket Material : Amazon.com : Automotive
or could I use some kind of high temp gasket from a tube?
Permatex 81878 Ultra Copper Maximum Temperature RTV Silicone Gasket Maker, 3 oz. Tube : Amazon.com : Automotive Permatex 81878 Ultra Copper Maximum Temperature RTV Silicone Gasket Maker, 3 oz. Tube : Amazon.com : Automotive
Old Mar 18, 2014 | 10:44 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Im not 100% sure, but i think you could use the exhaust manifold gasket stuff from that second link. If you can use it for an exhaust manifold then its safe to say you could most likely use it and be fine.
Ill also say i didnt look at the links, but if its the metal exhaust manifold gasket maker stuff you should be good. Unless someone else has a direct link to the gasket you need.
I didnt get to that point on my 2.8; the studs felt like they were going to shear after multiple pb blaster and heat cycles, so I just made myself a couple block off plates for the plenum and egr mount. Of course I wont have to deal with that when I put the turbo headers on
Old Mar 18, 2014 | 10:58 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: EGR to manifold gasket?
Old Mar 20, 2014 | 09:02 PM
58mark's Avatar
It came in the mail. Not only is it the perfect size, but it's made out of the same material as a manifold gasket. couldn't have asked for better if it had actually been made for the car.
Old Mar 23, 2014 | 11:04 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Holy crap! I never knew I could get a gasket for that! I use copper RTV on all of my exhaust joints and haven't had an issue (except for now since I have considerable gaps between my header flanges and the heads at the bottom of the ports ).
Old Apr 14, 2016 | 01:50 PM
mys10v8's Avatar
Car: 92 Camaro
Engine: 3.1L
I know this is an old thread but: Thanks for posting this. So many times the final solution for a thread is not posted because the OP figures it out and doesn't need to go back to the forum.
Nobody lists this gasket in their parts application guides for 90-92 3.1L. I knew it existed because I disassembled 2 in the salvage yard and they were there.
gta892000
Aug 11, 2019 11:16 AM
Kenwood
Sep 11, 2015 12:50 PM
Blue419
Sep 10, 2015 01:03 PM
hdis2002
Sep 8, 2015 02:52 PM
rjcme
Sep 5, 2015 01:23 PM
