Any carb'ed V6 guys left?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
All this new-fangled multi-port stuff... anyone still rocking the 2bbl?
Till I find a decent 350/383 for my baby that little 100hp beast will keep ticking!
Just wish I could spin the tires a little
Re: Any carb'ed V6 guys left?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Awesome! Though looking at your info I'm guessing you started with MPFI?
Wondering how many are still banging around with the stock carb motor!
Car: 1991 Camaro RS, 1991 Firebird
Engine: None, 3.1l LH0 V6
Transmission: None, 700R4
Axle/Gears: 3.42 Open, 3.23 Open
The Camaro had a V6 rockin' a carburetor, or did you guys mod one onto yours?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
82-84 were all carb'ed, V6 & V8. Oddly the 4 cylinder was fuel injected though haha
Hmm. Not bad. I am assuming you can't run that stuff on a LH0 from a 1991 car, yeah?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
cool, didn't know if they'd all be pulled out for V8's by now!
funny how you get that little burst of extra power when you open up that second barrel haha
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
I do actually. Swapped the intake for the 4 bbl Holley and I can tell you it was well worth it. Alot more bang, headers added more power. I still have the old intake and carb thrown in the backyard.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I didn't know they made manifolds for these! Does the car really need a 4bbl though? Must be a small one! haha
I'd like headers too but I think they're all discontinued.
Honestly I'd love to see what I can get out of this motor but I think it's just going to come out
the intake isnt cheap but it looks to be a good intake as it wont limit top end as much as the mpfi intake due to its much shorter runners
i would do a 260 delta cam .4bbl intake and the 390 carb , should pick up a whole bunch of power
one really nice cheap upgrade u could do is get a set of heads off a fuel injected 2.8/3.1/3.4 and bolt those one they have larger runners and valves and flow a bit more then the carbed heads , while u swap the heads do the cam as well for 100 bucks , that alone would be worth a good bit of power
one last cheap trick is to order the cheap non roller sbc 1.6 rockers or the cheap 1.6 roller tip rockers, what u do is throw away the piviot ***** that come with the sbc rockers as they have a 3/8's rocker stud hole, and just reuse the stock v6 piviot ***** in the sbc rockers , the v6 pivot ***** are 10mm stud hole, this costs about 50 bucks for the set of rockers
u can still order the pacesetter headers from summitracing as far as i know , but if u watch the classifieds here lots of v6 parts go up for sale and never get bought up
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Cool to know the newer heads bolt up. No modifications required? That'd be something I could do easy; probably pick a pair of those heads up for next to nothing.
If I could find that eddy manifold used I'd go for it too but with V8 plans in the future I don't want to spend much/anything on this slug! haha
if u do swap the heads swap the cam as well its 105$ shipped for the cam and lifters from delta and is a worthwhile upgrade, the only thing extra u need to do to swap the cam is to get the oil pan off but since u will have the heads off the engine it will be easy to lift the engine up the few inches u need to get the pan off
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Big problem with those was a sunken float, that filled engine with gas and then spun a bearing.
but poeple don't servie the carb's like they should, youll find many with the 2bb in the truck line also with a bad engine suddenly and no one puts 2 n 2 together.
Car: 1985 Camaro
Engine: 2.8
I remember my old 84 Firebird with the 2.8 carbed. It was given to me by my sister, because she didn't like it( it was her first car that she picked out). I think my civic would leave it, it was slow as crap. The body and interior were pretty good though...the interior was flawless. I was 16 at the time and my mom drove the car to the store one time......hit the brakes and it pulled hard. The instant she did that, I was told I couldn't keep the car. It also tended to not want to start a lot. Electrical issues. It had tons of wires not hooked up to anything under the hood. Paint job was terrible, but looked good. They didn't mask anything off. All the lights were blue.
Had $1500 on it....ended up selling it to my brother for $300 down and payments for $1000. I only got $300 before he ran it with no water in it and seized it up. I wish I would have just kept it and motor swapped it looking back. At the very least I'd still the interior.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
My advice is don't...
As for the headers. It's not the PaceSetter's that are hard to find. They're literally everywhere. Try finding Hookers (or whichever other brand that was the only headers available for the 2.8 F-body for years until they stopped making them before PaceSetter picked up the slack).
Upgrading the intake and exhaust alone will net big gains. I know for a fact that the exhaust crossover pipe on the older 2.8s is a smaller diameter than a FI pipe and may not have a bung for an O2S. And that's stock as far as I know.
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
If you like those rockers so much, you can have my set of 1.6 roller tip when I find someone to sell me a set of stock small port 3100 roller fulcrum non adjustables. I hate the ones I have sooo much. They rattle like crazy even being set to the point where the engine has max compression, they're still loose on the pivot points and rattle side-to-side.
A cheap trick for a little more power with those that have the stock 2bbl. is to grind the tab that limits the secondary from opening up all the way. And flip flop the air cleaner lid.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Do tell more of this carb grinding! And yes, I have the lid flipped haha
In the picture theres a circle around the secondary linkage, open the secondary flap by hand & see what's keeping it from opening all the way (flap should be vertical when all done).
I remember it was a piece of metal on the linkage arm that limited the opening angle.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Awesome, I'm all over that. Though I don't think it'll help too much as it seems to fall flat on its face when I mash the go pedal haha
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
shouldn't Doug Roe made comment as since the top air valve is connected to the needle, you can slap it wide open and have exact metering.
a deisng you may have seen put into a new Qjet if he lived longer. As that 2bb is just a qjet cut in half and then upgraded.
Doug Roe deisgned the Qjet for GM, his baby
sreZ28
Oct 22, 2015 08:21 AM
Damon
Sep 26, 2015 04:29 PM
