modded 2.8 dyno
Old Nov 4, 2014 | 02:17 PM
ice_man0617's Avatar
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
modded 2.8 dyno
Well went to the pepboys speed shop show sunday...they had a mobile dyno so i hit it...with a near stock cam (crane 2030) and other mods heres what i put down...sadly it was a 4th gear pull...(upset as hell)
Hp 125
Tq 168
It should have made more it was on a dyno jet but a lot of cars...i mean outlaw 10.5 cars were barely putting down 345...but yeah i have the sheet attached to but they didnt push the cars either..
Chart is attached and next part going in a high lift cam...crane 272
Old Nov 4, 2014 | 03:49 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: modded 2.8 dyno
what are the mods on it now?
Old Nov 4, 2014 | 03:52 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
Same as before outside of new suspension and tranny n tc...still no tune n the cam come to find out is barely bigger then the stock cam
Old Nov 4, 2014 | 04:09 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: modded 2.8 dyno
Yea a 272 will help alot. Are the heads ported out at all? That will help a ton with that bigger cam.
Old Nov 4, 2014 | 04:15 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
Ported to high hell the exh is ported to the size of my custom steel header gaskets. Siamese int with mani..and same for up/low plenums
Old Nov 4, 2014 | 08:49 PM
project89's Avatar
Re: modded 2.8 dyno
put a stock ported manifold back on it , that Siamesed intake is hurting it big time ,
272 cam is to big for a street car , put a 260 in it
Old Nov 4, 2014 | 09:46 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
How so is it hurting it...im asking because mine were damn near siamesed stock like gasket matched, i just had to port out the edges....and why do you think the cam is to high? Im asking for information. Not to knock you or nothing
Old Nov 4, 2014 | 09:57 PM
project89's Avatar
Re: modded 2.8 dyno
the 2.3/3.1 has a long runner intake hich makes its power low to mid range
when u siamiese it it moves its powerband way up , well the cam u have is basically the truck cam for towing i.e power down low so u want everything to match up
the 272 cam is a top end cam complete mismatch for the intake on the engine
the 260 cam is a upper low to upper midrange cam much better suited specially for a street car with stock gears and converter
u need all ur parts and mods to work together for the best results
look at ur dyno graph everything falls off around 3,500 to 4k rpms
the 260 cam would work ok withthe siamiesed intake
Old Nov 4, 2014 | 10:20 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
You might be looking at the wrong cam...it's a low mid range cam...it's the same one as am91 as well. And the dyno was a 4th gear pull too they didn't push any of the motors that day.
Old Nov 4, 2014 | 10:41 PM
project89's Avatar
Re: modded 2.8 dyno
opps was thinking about the 2020 , and 4th gear is the correct 1-1 gear to do a dyno pull in
call up delta and have them grind u the 260 grind on 114lsa with .475 lift, that cam is the **** , just dbl check to make sure u have retianer to valve guide clearance and that ur springs wont bind at that lift
its 105$'s shipped and way better then any off the shelf cam
other then that u did pretty well most 3.1's will dyno right around 100rwhp swap the cam and tune it and i bet u see 160 rwhp
the crane h-272-2 isnt to bad its much smaller then the other 272 grind cam out there, i keep forgeting crane has that small hydraulic 272 grind
Old Nov 4, 2014 | 11:00 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
Ok on the dyno...and imma stick with the 272 to be honest...and the valve seats, retainers and spring are the ones from crane spec'd for there cams and all were micd during installation...is that delta cam really that good? Has anyone else used it
Old Nov 4, 2014 | 11:02 PM
project89's Avatar
Re: modded 2.8 dyno
all of us pretty much use delta cams now fasteddie has the delta 260 in his 11 second hybrid, been trying to get him to upgrade to the delta 272 grind
if he got rid of that autozone converter in his car it would prolly go supper low 11's or really high 10's with that 260 camn in it
Old Nov 4, 2014 | 11:06 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
I know you guys use it ive seen the threads...most use the 260grind...but i was asking about the one you mentioned to me
Old Nov 4, 2014 | 11:08 PM
project89's Avatar
Re: modded 2.8 dyno
im not sure if fast has the stock 260 grind or the modified grind i mentioned he will have to chime in on that one i think he has the modified on 114lsa grind though
Old Nov 4, 2014 | 11:14 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
Ok...yeah i decided on the 272 because of am91 and the pennocks fiero forum...i wanna see what fast has too
Old Nov 5, 2014 | 12:03 AM
project89's Avatar
Re: modded 2.8 dyno
the 272 shoudl do well being u have a 5 speed car, if u really want to make it shine build a pizza box intake
be sure to check clearance for .480 lift it will be close , id also throw a 1.6 rocker on the intake side , and leave 1.5's on the ex side
Old Nov 5, 2014 | 12:35 AM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
It's a auto (seriously built one from monster transmission) you should check out my build thread, I have 1.6 roller tips as well...this motor is really a 3.3 but .7 ci extra I don't really bother counting
Old Nov 5, 2014 | 12:46 AM
project89's Avatar
Re: modded 2.8 dyno
in that case they didnt dyno it correctly, it shoudl have been dynoed in 3rd gear
so ur numbers are low but the graph should still read ok for the curve
what converter do u have in the transmission ? its going to want some stall speed witht hat 272 grind
Old Nov 5, 2014 | 12:50 AM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
yeah that's why I was saying that it should have been in 3rd gear but was sadly in 4th...and it's a 2000 stall but I can hold it up to about 2300 almost 2500 before it starts try and break loose
Old Nov 5, 2014 | 01:01 AM
project89's Avatar
Re: modded 2.8 dyno
that should work ok for that cam, sounds like the s10 high stall variant on the converter
do u have a wideband o2 on the car , the maf sensor does a pretty good job of keeping up with mods but an adjustable fpr should help ya dial it in a lil more
add 4* of base timing and run the r42 delco plug if u arent already
Old Nov 5, 2014 | 01:08 AM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
no wide band yet, fast and AM were telling me about them...bloody things are $$$ but I will eventually Fpr is on the list too, and 4* isn't that a little to far advanced? sad thing about the timing is I need to get a new balancer I spun my current one pretty bad...took it to my mechanic to so he could verify it,and well it's off by well lets just say alot smh. Are the R42s the rapid fires? If so I have them if not I'll look into getting them and if so can you tell me the differences between the 2
Old Nov 5, 2014 | 01:41 AM
project89's Avatar
Re: modded 2.8 dyno
acdelco r42tsk or r42ts i forget the exact part number they are the standard plugs for the 2.8/3.1/3.4 , they are just a colder plug then stock and one of the best plugs for these engines
stock is a r43 some years did get the 42's stock though
4* is fine i ran +6 on my turbo build which is alot more sensitive to timing then an n/a build
+4 will pick it up some in the mid and upper ranges , might loose a touch at off idle
the reason for the colder plug is to help prevent preignition with the advanced timing.
Old Nov 5, 2014 | 02:02 AM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
ok I here you think you might be able to get the part numbers for me and which of the 2 do you recommend, I had always thought that the rapid fires were good, but you learn something new everyday lol and once I get the new balancer I'll get them and do the plus 4*
Old Nov 5, 2014 | 02:22 AM
project89's Avatar
Re: modded 2.8 dyno
i know fast has the exact part number throw him a pm
rapid fires are ok , but ive found the stock ac delcos to be the best in these engines
Old Nov 5, 2014 | 02:29 AM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: modded 2.8 dyno
I'll do that thanks, I appreciate all the help
Old Nov 7, 2014 | 07:37 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
R42ts, you had it right Dave.
Old Nov 7, 2014 | 07:53 PM
project89's Avatar
Re: modded 2.8 dyno
thanks its my silverado that takes the r42tsk's
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
usafirebird
Sep 29, 2015 11:58 PM
