3.1 Timing problem
Old Jan 12, 2015 | 08:45 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
3.1 Timing problem
i need help on how to set the timing on my 3.1 v6 . so when i check the timing with the est wire hooked up its at around 16 18....so what i did was disconnect the wire and set it at 10..turn off car. . disconnect battery ..then hook back the est wire.then turn back on. did i do it right? Can anyone tell me the correct way to set the timing? do i need to be in park or drive? etc. because my car boga a lot now like its nissing. it doesnt pop but bogs like its not getting fuel. or could it be the timing? or a fuel filter problen? please help
Old Jan 15, 2015 | 02:32 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 3.1 Timing problem
For the timing on your car....
Start up the car and warm it up as normal.
Next, shut the engine off, and then disconnect the Electronic Spark Control (ESC) wire, its near the heater/blower box on the passenger side firewall. It is a one wire pig tail connector.
Then hook up your timing light. Start the car and point that thing down at the harmonic balancer. You will see the notch and hopefully its arround 10* timing btdc. If not then you have to loosen up your distributor hold down bolt a bit and turn the dizzy to get the timing to 10 BTDC degrees. If your car is basically stock and hasent had the ecm tuned, try to dial that timing around 10-12* 10 is preferable.
Once you got the timing where you want. Shut the car off, hook that ESC one wire pig tail back together, and your good to go. (I usually unhook the neg. bat terminal for 1 minuet once im done adjusting the timing. This is just to reset the ecm and any codes that may have been thrown)
Anytime you check your timing in the future always disconnect that ESC wire to get a true timing, and make sure your car is already warmed up and idling normally for the best true readings.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
the_nikfive
Aug 11, 2015 02:46 AM
