Valve Cover Gasket Replacement
Old Jun 28, 2015 | 01:20 PM
sonu1975's Avatar
Hi,
I have a Camaro 91 V6 w/ manual transmission and yesterday I noticed that while driving there was smoke coming from the right side of the engine (near EGR valve). I believe the valve gasket is leaking.
Do I need to remove the upper plenum, fuel rail, lower plenum and then remove the valve cover ?
If/any other things I need to remove or think about ?
Does anyone have pic of all the steps on how to replace the gasket ?
Many thanks !
Old Jul 1, 2015 | 08:46 AM
sonu1975's Avatar
Re: Valve Cover Gasket Replacement
No one has ever changed valve gasket on a thirden camaro
No need for pic if no one has it, just explanation in text would be fine.
Old Jul 2, 2015 | 05:26 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
To do a valve cover gasket, yes you have to pull the plenum and fuel rail. You will also have to remove the EGR/tube and coil/bracket. Get a Haynes manual if you are going to do this, not only will it have the steps, but the torque specs and sequence for the intake. For $20, it will come in very handy. Also, get new injector o-rings, its cheap insurance so you don't have to take it back apart when you end up with a fuel leak.
Old Jul 2, 2015 | 05:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
if you can see the leak, and clean the area well, a bit of RTV on a finger can often stop that when its a non pressure leak. v cover, oil pan... non pressure, can't fix oil coming out a head like that.......
spray ladies dedorant with baby power is a good leak tracer.
Old Jul 3, 2015 | 08:18 AM
sonu1975's Avatar
At last some ideas and help !
Thanks guys.
BTW Does it has to be ladies deodorant Aren't the deodorant flamable if I would spray in engine compartment while the engine is hot and running ?
Old Jul 3, 2015 | 12:23 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
You don't have to remove the intake manifold, but it does make it a whole lot faster. I'm lazy and am swapping to Fiero valve covers. I left the intake and what not on, and finished the driver's side swap. Working on passenger side today. Really, it's a pain in the ***, so it probably would have been better to pull everything and do it the right way.
And 2nd Haynes or factory service manual.
Old Jul 3, 2015 | 05:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Everything is flamable if hot enouh....... men don't use baby powder dedorant....
Old Jul 4, 2015 | 02:10 PM
sonu1975's Avatar
For a couple of years ago a mechanic i knew replaced the gasket between the upper and lower plenum and since I will be removing the plenum and other stuff myself I am wondering if I need to replace the gasket AGAIN between the plenum or can I re-use the older ones ?
Old Jul 4, 2015 | 03:13 PM
drdave88's Avatar
Engine: 6.0L
You can't reuse those gaskets. The intake gasket set is cheap enough, don't risk a vacuum leak.
Old Jul 4, 2015 | 03:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
could take a cereal box n ballpene hammer n make a gasket if you want to be really cheap.
rec did that for the water neck on my V8 car, worked like a charm.
Old Jul 6, 2015 | 04:32 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Try this first if it works it works, if not then go further.........
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
