electrical help ASAP!
Old Jul 14, 2015 | 01:33 PM
92projectcamaro's Avatar
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
so I decided to go ahead and do the 3.4 swap to get some more power bought the heads headers and a new intake which I ported (already did a camshaft upgrade) but now got everything connected and put back together I cant plug in my battery everytime I plug in the positive after that I go to do negative it sparks everywhere I made sure everything inside car was off and even started to unplug a few things the car had n such problem beofer swap
Old Jul 14, 2015 | 02:24 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: electrical help ASAP!
Small spark or big spark. A little spark is normal.
Old Jul 14, 2015 | 02:27 PM
Car: 1989 rs coupe
The more I touch the metal the bigger the spark gets
Old Jul 14, 2015 | 02:28 PM
Car: 1989 rs coupe
Like when I try to screw it in I can here it pop and see a few sparks
Old Jul 14, 2015 | 03:15 PM
Car: 1989 rs coupe
I'm like out of ideas of what to do
Old Jul 14, 2015 | 10:13 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
From what you describe it sounds like your positive cable is grounded somewhere. Start tracing it and see if it's making contact anywhere, especially at the alternator or starter. I would think that if it was a smaller gauge wire you'd have already fried it or a fuse, but I wouldn't rule it out for sure. It could be that you have a pinched wire after doing the work.
Old Jul 14, 2015 | 10:15 PM
Car: 1989 rs coupe
So first trace the positive wire to wear it leads and then search for a pinch wire I check all fuses and plugs all seem to be okay that's while I'm so stumped
Old Jul 15, 2015 | 08:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
or someone used all black cable somewhere and you instantly thought black meant ground???
Old Jul 15, 2015 | 09:40 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
if you have a fluke meter or a meter put it on battery and neg cable and see what amp your drawing mine sparks alot i just have to be quick
Old Jul 15, 2015 | 09:41 PM
Car: 1989 rs coupe
I mean mine like pops and cracks and starts smoking
Old Jul 15, 2015 | 11:24 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I would disconnect the battery, grab a multi-meter and ohm from the positive cable to ground (engine block or frame). If you find that it's shorted, start disconnecting things until the short is found.
I'm wondering if you pinched anything during the install?
Old Jul 15, 2015 | 11:27 PM
Car: 1989 rs coupe
I check all wires I unplugged during swap all good but I could have pushed something out of my way or jammed something in a place it shouldn't be lol
Old Jul 16, 2015 | 02:37 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
I like scorpners idea, I will remember that one !
Its easy to miss something when we are putting engines in, it happens, youl find it and youl have a great car , good luck !
Old Jul 17, 2015 | 03:49 PM
Car: 1989 rs coupe
So guys looks like we may have found the problem looks like the starter was fried / shorted and kept calling for the electricity and was stuck on checked all the ground wires coming off the start all had good continuty. Thanks for everyone's help I'm about to replace starter pray it works lok
Old Jul 18, 2015 | 06:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
probably just the solinode that needs changed, or smacked with a rubber mallet, that or you put the start wire in the wrong spot and its active all the time.
Old Jul 18, 2015 | 06:39 AM
Car: 1989 rs coupe
No it's was like broken broken the copper cassing inside broke into pieces
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
92projectcamaro
Sep 24, 2015 08:09 AM
