engine isnt starting
Old Aug 5, 2015 | 10:26 PM
92projectcamaro's Avatar
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
okay i have a 1992camaro 3.1L
I decided to start going for more speed I did the ported 3.4 swap I replaced the dizzy rotor and cap new plugs new wires fuel rail rebuilt new ignition coil new pushrods new starter.. I turn the key and the engine cranks but that's it no grumble no growl nothing at all just the motor spinning
I Need SOme HELP!
thanks
Old Aug 6, 2015 | 11:31 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: engine isnt starting
I always go right for the starting fluid to figure out what it is on no start.
If it tries to run, you know its a fuel problem.
If it won't even pop on SF, you know its a spark problem.
Old Aug 6, 2015 | 01:08 PM
Car: 1989 rs coupe
That's what I was gonna do when I get home lol
Old Aug 6, 2015 | 01:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
FYI I do not suggest using it for a band-aid on starting, only for testing purposes. Ive had the same can about 10 years, has a few squirts left
Old Aug 6, 2015 | 01:15 PM
Car: 1989 rs coupe
Inky time I ever really used it was in the winter she wasn't afan of the cold lol
Old Aug 6, 2015 | 01:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If you "have" to use it, some auto stores but for sure a truck stop will have the better SF that has lube in it. As its harsh to use for constant starting, but some diesels need it, so they put top end lube in the better brands.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
