need help
Old Jan 18, 2016 | 11:18 AM
89fbodyboy's Avatar
need help
I have a 89 camaro with the 2.8l I blew a head gasket so I sent it to a shop I also broke a tooth off the timing gear well he fixed all that I guess lol but he took 3months to do that so before he had it properly running very pissed wanting my car back I told him to take it back to my house cause he said it would be another week or two for it to be done well I got it home got it running well got it to idle right so I was going to test drive it I jump in take off going down the road car is doing everything properly but I noticed I'm driving and engine is reving up normal but it is not gaining speed in 2nd gear I'm doing maybe 25mph and rpms are way to hi to be going that slow and idk what the problem is please help
Old Jan 20, 2016 | 11:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: need help
Punctuation is very helpful. I had to read it a few times to get what you were saying. So you had a head gasket blow, some guy half way fixed it, you got it home and finished the repair yourself and now you think the RPMs are too high at 25mph. Let's start here:
- Is this an auto or manual car?
- What are the RPMs at when you're doing 25mph?
Old Jan 21, 2016 | 07:05 AM
89fbodyboy's Avatar
Re: need help
Manual and bout 6500 rpm between 25-30 mph
Old Jan 21, 2016 | 09:44 AM
drdave88's Avatar
Engine: 6.0L
Re: need help
Lacking serious power, are you sure timing is correct, both the distributor and the timing chain? Did you over tighten the rockers and have a valve or more sticking open? Does it start hard at all, both warm and cold? Where does it idle both warm and cold?
Old Jan 21, 2016 | 09:53 AM
89fbodyboy's Avatar
Re: need help
When I get I started it idles normal maybe 1k, but he said he made sure the timing was right. Is there any way u or some else could give me all info to tear it all back down and do it right from timing Chain up, I coulda done it the first time just didn't wanna do the research.
Old Jan 21, 2016 | 11:15 AM
drdave88's Avatar
Engine: 6.0L
Re: need help
You need 2 things if you don't already have them, a manual (Haynes or similar) and a timing light. Check your timing first before you tear anything apart. 1k RPM is high at operating temp, may have a vacuum leak. Do you know if the idle set screw was messed with at all? It shouldn't have been, and despite what other threads say on here, you shouldn't ever have to adjust it, the ECM controls that. If your idle is wrong, something is wrong. You don't have a check engine light on do you?
Old Jan 21, 2016 | 12:16 PM
89fbodyboy's Avatar
Re: need help
To my knowledge no check engine light,but I think I do have a vacuum leak but I can't find a good enough diagram to figure it out. I also founda sensor on the passenger side behind the head bout, six inches away from the ddistributor that is broke off and I do not know what it is
Old Jan 21, 2016 | 01:30 PM
drdave88's Avatar
Engine: 6.0L
Re: need help
Take carb cleaner and start spraying it around the vacuum lines and the intake manifold, if your idle changes, you found your leak. Take a pic and post it, but if you are talking about a sensor on the driver side of the back of the block, that would be the oil pressure sender. I'm guessing your oil pressure gauge doesn't work then?
Old Jan 21, 2016 | 02:06 PM
89fbodyboy's Avatar
Re: need help
I will try the carb cleaner and yes thats the sensor idk if the oil pressure gauge worked I only had it 3 weeks before the head gasket blew and timing gear chipped
Thirdgen89GTA
Apr 6, 2016 08:02 PM
defaria27
Dec 13, 2015 12:06 PM
ashleysierra96
Dec 6, 2015 12:36 PM
greasegrenade
Exterior Parts Wanted
Dec 6, 2015 10:55 AM
Djmathis123
Dec 3, 2015 08:14 PM
