91 firebird 3.1 shutting down
Old Apr 6, 2016 | 04:28 PM
vtype's Avatar
i have replaced the ECM,Distributor,TPS,Knock Sensor,Plugs and, wires as well as a group of other items and when i start it it runs great till it reachs normal running temp it gets rough then dies and wont restart till it is totally cold. 123,000 O/M regular oil changes were always keep up
please help
Old Apr 6, 2016 | 07:23 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 91 firebird 3.1 shutting down
Did you replace the ICM, ignition control module? When these get hot, they fail and your spark fails. Also, ohm your injectors, check fuel pressure, and check to see whether you have a ruptured diaphragm in your FPR, fuel pressure regulator. Good luck.
Old Apr 7, 2016 | 08:00 PM
vtype's Avatar
yes i did
. heck had a Pontiac dealer went as far as changing the steering column. good fuel pressure it never looses good spark even when it shuts down
Old Apr 7, 2016 | 08:50 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Egr?
Old Apr 7, 2016 | 09:09 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Wiring harness.
GM had a big recall on engine harnesses for the 3.1 cars. Something about the ignition wiring was run through the harness wrong and would rub through the insulation on the wiring causing problems. My parts worked 100% on the 2.8 harness. Throw the 3.1 harness in and it would shut down randomly when hot but refire after a few second cool down. Remove and swap harnesses again and everything's peachy... Wiring harness fault. Not entirely sure what as I cut up that entire harness and found no damaged wiring anywhere at all but the issue was definitely in the harness. And yes, this was between 2 ECMs and a couple MEMCALs also.
Old Apr 8, 2016 | 09:25 AM
southbay08's Avatar
sounds like failing coils in the injectors to me. If they are the stock injectors if they are going to fail it is more common when the injectors are warm/hot. Check the resistance on them.
Piston454
May 31, 2016 12:04 PM
Albani
Apr 11, 2016 11:02 AM
Rumblebee
Apr 11, 2016 10:47 AM
dbthe1
Members Camaros
Apr 8, 2016 12:17 AM
1985chevydude
Apr 6, 2016 08:35 AM
