What did you do to your v6 today ?
Old Sep 6, 2016 | 11:25 AM
  #101
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: What did you do to your v6 today ?
Originally Posted by ktthecarguy
The car runs, but takes a while to start first time when cold. After that, it runs ok, but gets horrible mileage. Might be unrelated though.
Right now at the shop, just waiting for a call back.
Hi, I just wondered what they checked before putting a new ecm in it, like thats the very last thing id do ! Unless I had one sitting here to try . Using too much fuel id say the pumps prob ok .
Old Sep 6, 2016 | 11:30 PM
  #102
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi zs&tas,
They checked the ECM, and said it is okay. And the fuel pump circuit is turning on. And the pump is priming. Getting 40PSI at the fuel rail when running, 45PSI when primed.
they are resetting the codes, then testing again. Gotta wait until morning.
Old Sep 7, 2016 | 03:30 AM
  #103
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Hi zs&tas,
Sounds like everythings good but its throwing a code. The oil pressure switch needs to be checked too, other than that a bad conection somewhere ? If it wasnt throwing that code id be looking at other stuff for the horrid millage .
Old Sep 7, 2016 | 03:48 AM
  #104
On Probation
I think one big culprit is the exhaust. The other day I found the down pipe loose, about 1/2 inch gap between the exhaust manifold and the down pipe. Big air leak, possibly throwing off the O2 sensor readout. Loud too.
Old Sep 8, 2016 | 03:44 AM
  #105
On Probation
Well, ECM and fuel pump tested out great. New code is 14 (I think) O2 sensor error. So I need to fix the exhaust downpipe. One side is loose with a BIG air gap, the other side is held together with a muffler clamp. Yes, a muffler clamp! Will I ever be done fixing all the sh*tty half-azzed "fixes" this kid did?
Still working on the front suspension and steering. It's all worn out, so I am replacing it all. Took me one month to do one front control arm. Hopefully the other one goes faster!
Old Sep 10, 2016 | 01:56 PM
  #106
project89's Avatar
Originally Posted by project89
helicoiled all the rocker stud holes in the 3400 heads , hopefully ill get the car back together soon
finally got the motor together yesterday , and instead of taking i easy on the car for a few days to make sure no isues , took it on a 300 mile drive
only issue that has poped up is i have a missfire at idle , but i belive its just the egr leaking so ill look into that today
turbo goes on after i find out whats causing the missfire , the missfire is only there below 900 rpms
Old Sep 10, 2016 | 08:34 PM
  #107
inkscape's Avatar
Car: '91 Chevy Camaro RS
Engine: 3.1L LHO V6
Transmission: Borg Warner T5
Axle/Gears: GU6 3.42 Open Diff
I did something less positive with my v6 today. Found a damn gasket spraying coolant I think. Not the water pump, but behind that I assume is the timing cover? It's spraying between the block and the timing cover. FML
Old Sep 11, 2016 | 08:03 PM
  #108
project89's Avatar
well i found out its nly missfiring once the engine gets hot ( normal op temp ) which seems odd to me , maybe a failing coil pack? or would it be the coil pack base plate which is also the moudle iirc
Old Sep 12, 2016 | 08:56 AM
  #109
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Yea the base is the Icm on that dis set up. Could be that. Although I've never had a flacky one like I've had many times on the old dizzy set up on our cars stock.
Old Sep 13, 2016 | 04:02 AM
  #110
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
haha, i know that feeling ! keep at it mate
ive got the firebird pop up light issue, factory grease poo pooed, doing the rubber hose inside the gear fix. so far so good, one side done...... fitting new bulbs while im there too, i would do headlights but its all money aint it... it never stops !
Old Sep 21, 2016 | 07:25 PM
  #111
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Transmission: THM 700R4
Well last week my heater valve went out after only a year and a half so i went and bought another. took my car from memphis to mid illinois and back and next morning heater valve was leaking so i went and exchanged it and bought new heater hose and replaced the 3 hoses attached to it. After this i started the car to a horrible squeel, and thought...crap it's the barrings in the water pump i just replaced in Jan. FML !..... but then i noticed that all of the pullies were filthy and hit them with a wire wheel and no more squeek....So thankful, but am loosing my voice from cussing so much....Overall....productive day.
Old Sep 21, 2016 | 10:01 PM
  #112
inkscape's Avatar
Engine: 3.1L LHO V6
Sounds like me when I was trying to pull my harmonic balancer off to fix the gasket behind my timing chain cover. Went through all cuss words and probably even came up with some new ones.
Old Sep 22, 2016 | 04:41 PM
  #113
project89's Avatar
trying to figure out were the water in my oil is comming from , took the rossover pipe off and its all comming from the rear head , so now i need to pull the head and see why. i.e bad gasket , cracked or warpped head , or cracked block
what im going to do since it fills the cyl with water when the engine is off and the cooling system is presurized is. first get the motor warm so theres presure in the cooling system , then give it time to fill the cyl before draining the radiator , then ill quickly get it torn down so i can get the rear head off and see which cyl is full of water to narrow down the area of the gasket and which cyl i need to inspect
Old Sep 22, 2016 | 06:48 PM
  #114
inkscape's Avatar
Engine: 3.1L LHO V6
Going to take a guess on that as a bad gasket... Just a guess.
Old Sep 22, 2016 | 08:41 PM
  #115
project89's Avatar
brand new gaskets , thinking the head is warpped as i didnt check it before i put it on this time , the first time i checked it it was a lil out but it sealed, i had to pull the head the 2nd time to fix a rocker stud that had pulled out .
instead of just repairing the one on the motor i decided to pull the head and do all 6 studs with helicoils
probably would have been better off just helicoiling the one stud without removing the head
Old Sep 23, 2016 | 07:20 PM
  #116
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
So yeah getting mad because my belt stared squeeling again while i am sitting at a light i hear a clunk and the squeeling stops. So a block later i pull up to her work and pop the hood to this. Thhis car just doesn't stop breaking.
Attached Thumbnails What did you do to your v6 today ?-734763_1431254173559026_1943769124473398460_n.jpg
Old Sep 24, 2016 | 01:02 AM
  #117
inkscape's Avatar
Engine: 3.1L LHO V6
Holy ****!
First thing I'd do if I were you, replace the bracket and replace all of those bolts in the front end including timing chain cover bolts, waterpump bolts, etc with all new ones and torque to proper spec with some anti-seize or oil. whichever you prefer.
That broken head may have been the reason it did that. Could be wrong as I am in no means a master.
Old Sep 24, 2016 | 09:25 AM
  #118
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Primed the rear quarters and roof #gettingthere
Old Sep 24, 2016 | 07:39 PM
  #119
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Yes i agree that may have caused it but the funny part as you can see i have just replaced the waterpump, timing cover and all bolts those were new lol....good thing i have spares, and good parts guys!!
Holy ****!
Old Sep 27, 2016 | 05:48 AM
  #120
fasteddi's Avatar
Car: 1991 Camaro RS
Also it may be visibly obvious if one of the combustion chambers is cleaner then other from being steam cleaned or one of the runner/s is cleaner then the others.
Old Sep 27, 2016 | 06:20 AM
  #121
project89's Avatar
center rear cyl , head was warped .016, i shoulda checked the head before bolting it back on, piston is nice and clean now i gota take the time to clean the other 5 before i put it back together , which also means having to spend the time to port another set of heads , since i cant get the current heads cut due to lack of machine shops
Old Oct 2, 2016 | 09:28 PM
  #122
project89's Avatar
i got lucky and was able to pull a favor at one of the old machine shops in the next town over, they only work on diesel stuff now but they cut the heads for me .
just waiting on gaskets and headbolts to come in so i can reassemble it
Old Oct 5, 2016 | 05:15 AM
  #123
fasteddi's Avatar
Car: 1991 Camaro RS
I finally got my ptc converter from lane in the mail yesterday. I'm beyond excited to see how this converter responds. It's a nissian core billet 9.5 inch converter. Custom to my engine and specs. Hopefully right arround 4500-5000rpm stall. I never thought I'd have a 1k dollar custom converter but they are the best in the business and their name speaks for themselfs.
I'll post some pics after work.
Old Dec 10, 2016 | 02:49 PM
  #124
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Another close call as i was stopping right pass front brake line popped and no brakes...fixed it. Now i just have to fix the drivers door from sagging. Bottom pin needs replaced.
Old Dec 11, 2016 | 02:48 PM
  #125
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
It was slow @ work so I pulled in the camaro
Replaced the lug nuts
Installed 2 new rear tires
Replaced my rear end cover
Fixed my water pump leak
And some light eletrical work
Old Dec 11, 2016 | 02:52 PM
  #126
THEBEAST84's Avatar
Old Dec 11, 2016 | 02:54 PM
  #127
THEBEAST84's Avatar
Old Dec 11, 2016 | 07:52 PM
  #128
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
I looked at her and asked why she's still playing the "Won't Start" game
Old Dec 27, 2016 | 05:38 PM
  #129
Jokersall's Avatar
Finished the waterpump install. added coolant. noticed it look like someone went dookie after letting the car run a few minutes. use rag to absorb mystery car dookie. let the car run without rad cap off while i went in to pee. watched old faithful go off about the time i got back to the car. shut car off. tried straightening hood while engine cooled. broke the body hammer. shut hood and went inside.
Old Jan 12, 2017 | 07:08 PM
  #130
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Finally have the bird back on the road today. Replaced the trans mount with an ES poly, and replaced the output shaft seal.I'll post a pic of the new mount tomorrow. Now i have no stress.
Before the new ES Trans mount and output seal
Also Noticed this which i will be doing next...smh
Lifed the car up with a chain hoist...Don't try this at home!
Set my stands and lowered car
How my mount was
Totally shot!
Old Jan 15, 2017 | 08:13 PM
  #131
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
So i was back under the car again today and replaced the rear sway bar end links with ES links to match the front tie rod ends and the trans mount.....slowly pice by pice it's getting new Es suspention. The both were fused so bad they broke off and was still a pita to get off.
Old Jan 29, 2017 | 07:50 PM
  #132
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
At it again! Today i took my drivers door off and repaired the uper and lower hinge pins. No more saggy door!
Old Jan 29, 2017 | 08:01 PM
  #133
Jokersall's Avatar
Tried trading it off for a home made pickup bed trailer camper.
Old Jan 30, 2017 | 05:10 AM
  #134
fasteddi's Avatar
Car: 1991 Camaro RS
On my 12 hrs off of work for the week I tossed on my adjustable. Tq arm, finished up the new x member built for the th350 with a different loop on it.
Old Feb 20, 2017 | 01:32 PM
  #135
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Think winters getting over, weather was alright, fitted some trim, new rear view mirror (shut the door once and it smashed onto the gear stick)
Checked t top rubber and cleaned up a bit. Goes for a test tmrw so fingers crossed, not been running two months not been driven 4 years..........
Old Feb 21, 2017 | 02:35 AM
  #136
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Shes being let free........
Old Feb 22, 2017 | 04:05 AM
  #137
On Probation
WOOHOO!
Old Feb 22, 2017 | 04:14 AM
  #138
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
WOOHOO!
yeah ! Drove her to the test and the long way back, drove alright with old dirty fuel. It failed, im working on her now , nothing too major though. Bits of steering link and stuff, ive got all the parts just spending the money to get her legal on road first then in a few months ill put her in for a front end overhaul.
This car drives completely different to my 92 auto. Its so light it bounces down the road and with the ridiculously obnoxious exhaust everyone jumps outa the way , kinda of like driving a wasp !
Old Feb 22, 2017 | 08:32 AM
  #139
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
New idler arm fiitted, tough getting old one off. Rear brakes checked, cleaned and free'd up, new indicator relay to be wired up.
need a set of plastic wheel nut covers, expensive here though. Can anyone post a set from a scrapie to the uk ?
Also noticied some slight rear wheel movement horizontally in and out of axle. How much is normal ? Acceptable ?
Old Feb 25, 2017 | 06:04 AM
  #140
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Retested today and passed , all legal and on the road ! Pretty cool drive home , found a crown vic police car cruising down the road - rare in the uk , hung with him for a bit.
Old Mar 2, 2017 | 10:13 AM
  #141
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
So i am at it again....replaced the drivers door handle about a month or so ago...go to get in it today and door won't open. So i go to the other side unlock and try to open from inside and the damn handle snapped.....this car really knows how to throw a fit....and that's why i call her Christine. What a b*tch.....
Old Mar 2, 2017 | 11:20 AM
  #142
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Christine lol that sucks man. I drove mine to work today then filled up just outside work and only one light would come up. Poop. Something else to look at .......
Old Mar 6, 2017 | 08:33 AM
  #143
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Been driving her around, the suspensions loosening up a bit now, still got a lean we cant work out but whatever .
checked the timing today, dam thing was at 4° , got it at nr 11° on the side of ten though. Drives much smoother and more responsive.
Well when i first got her she wouldnt rev past 4200rpm and she now goes up to 5200rpm which im happy with , progress ! ive gradually managed to get higher and higher over the years.
Old Mar 9, 2017 | 12:20 PM
  #144
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Fixed headlight issues, took off the duke style Dixie horns as they arnt working.
Old Mar 10, 2017 | 10:23 AM
  #145
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Drove it to work, much smoother and quieter on new timing.
Really need to give the brakes attention they are BAD.
Old Mar 13, 2017 | 12:32 PM
  #146
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Ok, drove to school to pick up my kid and outside it was not idling right and sound like it was struggling missing, then drove 30 mile round trip with me paronoid but it seems to have cleared. Idled fine out side my house, best check codes ? No idea what was going on lol
Old Mar 13, 2017 | 02:32 PM
  #147
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Code 34. Maf or ecm connection issue, pretty sure its the maf as I've moved it a little and the cable needs sitting nicer.
Took my lad to the American diner, guess you guys just call it a diner lol.
Old Mar 14, 2017 | 10:54 AM
  #148
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Maf conector is a bit greened up, ive got contact cleaner on it, been looking at fitting some lights underneath just in front of the skirt, like gumbys. Really cant see they are even there until you walk away from the car, think theyl look awesome, ill post pics when im done. Also i have a nicier plate on the car now
Old Mar 14, 2017 | 03:42 PM
  #149
fasteddi's Avatar
Car: 1991 Camaro RS
Worked on mine for a short while the other day. Got the accesories on there, nitrous stuff, radiator and hose, and braided trans lines. Hopefully within a few hrs i can start it up and break in the new engine.
Then i just have all the wiring inside, and the swing outs on the cage to finish up.
Old Mar 15, 2017 | 02:20 AM
  #150
On Probation
lol yeah, and in China, they just call it "food". That's a cute diner. Good going, take your boy everywhere, and he will grow up to be a gearhead. And have nice memories of the two of you together! Win-win.
