What it is and can it go away?
Old Jul 18, 2016 | 10:27 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys, I'm trying to do a wiRe tuck on my 2.8 and I came across the vacuum gig here on the coil bracket. What does it do and can it go away?
Old Jul 18, 2016 | 10:40 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: What it is and can it go away?
Well that looks like you EGR Solenoid. From the way I'm looking at it, that little tube is the vent for solenoid. Is you EGR still in play on it?
Old Jul 23, 2016 | 03:05 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
EGR solenoid vacuum sensor switch. Cannot be deleted or you WILL have a code 32 all the time. And do put a vacuum hose on it again... Preferably T'd into the line running between the solenoid and the EGR valve...
Old Jul 23, 2016 | 05:43 PM
I figured that out, I was having an EGR issue and after replacing the valve and fixing the hose is fixed it. Thanks
BluFBdy
Jun 27, 2016 03:32 PM
JoeMonte
Jun 27, 2016 11:51 AM
thomashearts
Jun 26, 2016 08:46 PM
firebirdchick28
Jun 19, 2016 08:02 PM
