V-6 sizes....
Old Dec 31, 2001 | 01:38 PM
90CamaroRSGuy16's Avatar
V-6 sizes....
Hey,
What's the biggest V-6 on the market? If I were to put a V-6 from a 4th gen in my car, would I have the stock hp? (205...I think) or, would it be about the same price to put a 350 in??
-Zach
Old Dec 31, 2001 | 03:49 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
ur goin to get more cheaper horsepower from a 350 then u can a v6. now with that said, its ALOT cheaper to use a 60* v6 (2.8-3.1-3.4) a turbo 3.4 will make bout the same power as a stock-slighty modded 350 with alot better gas milage and cheaper insurance. with that all u need, as far as i know, is the 3.4 long block, turbo, and a new tranny would be a good idea with that setup. if u goto a 90* v6 (3.8-4.3) or a v8 ull need to replace EVERYTHING. if i had the money i would have done a v8 swap into my '83. but after i looked into it and found i needed to replace alot of stuff that worked on my car, i decided it wasnt worth it. if u have smog where u live, ull have to take that into consideration too. i hope this helps. if im wrong on anything i hope someone on here with more experience than me will correct me.
mike (loomdog)
Old Dec 31, 2001 | 03:56 PM
loomdog32's Avatar
Car: 82 Camaro Z28
the biggest chevy v6 i know of is a 4.3 (i could be wrong on that).
the fourth gens used 2 different v6s. 3.4 bout 160 hp(60*, direct replacement in a 3rd gen) and 3.8 bout 200 hp(90* buick engine, bout the same cost as doin a 350 swap)
Old Dec 31, 2001 | 04:06 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Has anybody here tried this or thought of trying this btw? I was kind of considering it if I found a good deal on a cheap, nice V6 thirdgen. What do you think the max power would be on a heavily modded, turbo 3.4?
Old Dec 31, 2001 | 11:56 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
if we did turbo a 3.4 wouldnt we need to LOWER its compression???
i believe it has 9.1:1 compression which would be rather high for a turbo or supercharger
please correct me if i am wrong
Old Jan 1, 2002 | 12:11 AM
87RS402's Avatar
You can run 9:1 compression, you could even run 13:1 compression. The problem is when you raise mechanical compression you have to lower boost psi. (not that the following #'s are correct but they are an example) If you were to lower the ratio down to 7.5:1 you can easily run 12 psi of boost, with 9:1 you could only run 9 psi. Since boost is where your getting your power you want lower mechanical compression but you don't have to have it.
Old Jan 1, 2002 | 12:25 AM
ok thanx for the clarification, dude
the 3.8 supercharger runs 6 lbs of boost....and i heard that it will bolt up to 60* engines...................
Old Jan 2, 2002 | 01:47 AM
loomdog32's Avatar
Car: 82 Camaro Z28
i dont remember where i say this, it was like 1-2 years ago tho. the some turbo that was made for the 3.8 in 4gen f-bodies had an adaptor to work on 3.4 4gen fbodies. im ASSUMING that u could use this setup with a 3.4 in a 3rd gen f-body. i am goin to look up info on this and post what i find out.
Old Jan 7, 2002 | 05:11 AM
89camaroRSV6's Avatar
loomdog,
woudl that turbo really bolt on to a 2.8 keep us posted/....
Old Jan 7, 2002 | 06:49 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I am currently working on putting a turbo into my car, but am saviving up for the 3.4 first. I am thinking of porting the 2.8 heads to lower compression I experiment.
Old Jan 7, 2002 | 03:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I knew someone would bring this up.
Nixon1
Sep 4, 2001 10:18 PM
super83Z
Jun 8, 2001 02:02 AM
jm91rs
Dec 14, 2000 12:07 AM
Vader
Oct 18, 2000 08:32 PM
MY Z ROCS
Jul 28, 2000 09:31 AM
