Help......I can't even get my tires to spin
Old Jan 3, 2002 | 03:10 PM
90CamaroRSGuy16's Avatar
Hey,
This may sound dumb to some of you older users, but with only 140 hp, my tires wont even spin. Does that have to do w/ just the hp? At what hp will tires spin? My friend has a formula 305 that she let me drove....I can push the gas pedal down about halfway and the car will burnout (yeah, I know it's not good for the tires.....) So how can I add quick & cheap hp or whatever I need to spin my tires?? thanks -Zach
Old Jan 3, 2002 | 04:01 PM
Monkie's Avatar
LOL Try pressing the brake just enough so it doesn't move then press the gas and it should spin. I just dump the clutch at 2500 rpms and they light up.
Old Jan 3, 2002 | 04:10 PM
Drew's Avatar
It has more to do with gearing, tire wear, tire quality, road conditions (including weather), etc then it does with HP. If you want to do super smoky burnouts everytime you hit the gas get some store brand tires with a treadwear rating of 5000 and they'll just shread like the eraser on a pencil. Or if you have a clutch you can rev and release, but it gets old. Keep in mind anytime you're spinning the tires the car isn't going anywhere as fast as what it could if the tires were sticking. Also having to replace tires once a year sucks ***.
Don't abuse your car to make it spin the tires, you'll just look like a total dumbass in the process.
Old Jan 3, 2002 | 04:12 PM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
Get a v8.........or, for a cheaper method, vegatable shortening smeared liberally onto the rear tires should also do the trick. Thanks for the laugh!
[img]c:/car photos/iroc sig..jpg[/img]
Old Jan 3, 2002 | 05:36 PM
Monkie's Avatar
Newbie Do you have a V8? If so what does it run?
Old Jan 3, 2002 | 06:00 PM
WaynesRS's Avatar
burnouts aren't everything man
Old Jan 3, 2002 | 06:12 PM
Dave's 89's Avatar
Car: 89 IROC-Z
I have a nearly stock LO3....Probobally runs a mid to high 15
So what...Wish I could say it ran a 10, but i've had the car for 3 months, and make $7.50 an hour. (not that bad for 17 years old)
btw...was I bragging in the above post?
Old Jan 3, 2002 | 09:16 PM
89-28gp's Avatar
Car: 1986 Firebird
Engine: not stock 2.8
I wish my 'Bird didn't burnout half as much as it does. I'm looking into wider tires to help it out a bit. You lose too much jump in a race
Old Jan 4, 2002 | 03:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When's the last time the car had a major tuneup? (And I don't just mean plugs and wires and air filter, either!) A couple people found out after following my major tuneup list that they could finally spin the tires, so maybe that's all you need. Find the information here: https://www.thirdgen.org/techbb2/sho...threadid=62882
Old Jan 4, 2002 | 06:13 PM
Camaro_hunter_d's Avatar
Well I don't have to dump the clutch to get mine spinning. A soft rev to 2k and slowly releasing the clutch and continue the throttle burn 'em every time for a good 50 feet...... But I also have to hold 1st to do it. I can chirp 2nd hard at the shift. And No I do not recomend you spinning them alot.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
