Oil leak and exhaust questions.
Car: 1986 Camaro
Engine: 2.8
So I am in the middle of rebuilding my transmission so I can get my Camaro running after 15 years in my garage. I had a pretty decent oil leak for most of the years I was driving it. It appears that it might be the front main seal, but I’m not 100% sure, the whole pan is oily and dirty. How much do I need to lift my motor to drop the pan to replace the gaskets?
Also, it looks like my exhaust is touching my oil pan and one strut mount, I’m a little worried that the exhaust will heat up my oil, any ideas as to the best way to adjust the exhaust away from the pan. It looks like the bottom of the exhaust has a little road rash, so may have been pushed into the pan, oops!😜
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Oil leak and exhaust questions.
You're going to have to remove the distributor to lift the engine up far enough to get the pan out. Even then, you'll just barely have enough clearance to get it out. It's not fun at all to do in the car. You can't route the exhaust away from the oil pan, just the design of it. The exhaust does not heat up the oil enough to cause any issues, so I wouldn't be worried about that. You said the exhaust is touching a strut mount, did you mean a motor mount? The strut mount is located above your wheel, on top of the strut by the coil spring and wheel hub, etc.
Car: 1986 Camaro
Engine: 2.8
Your right engine mount (I was tired last night!). Thanks for the info on the oil pan, still debating if it’s worth fixing the leak, with that much work I may just live with the leak.
So the hot exhaust shouldn’t be an issue touching the oil pan? Not that I’m too worried, this car won’t be a daily driver anymore, so the oil will changed with low miles.
Engine: 6.0L
No it won't be an issue. We would all have the same issue otherwise. The only issue it may cause is a really annoying noise from the pipe rattling against the pan all the time lol.
Car: 1986 Camaro
Engine: 2.8
I did look at it again, the pipe is rubbing against the a-arm pivot point, so we were both wrong, I’m thinking it should be too big of an issue, worst thing that could happen is it would dent the pipe!
Car: 1986 Camaro
Engine: 2.8
Engine: 6.0L
The oil around the pan could be from a combination of leaks; front cover, oil pan, front crank seal...... It'll be impossible to tell unless you completely clean it all up and then watch for where it starts leaking out of. As far as the throw out bearing goes, pull it out and see how it feels turning it, it may be about time to replace it if the grease is coming out like that. Since you have the trans out and it's right there, I'd just replace the bearing, good insurance if no other reason.
Car: 1986 Camaro
Engine: 2.8
I’m cleaning up everything to see if I can find any leaks and going to paint the undercarriage while things are out.
hydrolic144
Nov 11, 2010 05:20 PM
ATCharming
Jun 29, 2009 03:33 PM
