Heated O2 sensor help needed
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
I have been having problems with my O2 sensor hot getting hot enough. I installed a 3 wire O2 sensor but it only preheat to 399. I've tried 2 different sensors, same problem
I've got headers, a free flowing thrush muffler and open pipes the rest of the way out.
Anyone else have this problem?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Heated O2 sensor help needed
First test to do might be to find out how many amps it should use and then measure how many it's pulling. I actually don't know how hot they are supposed to get. I never had problems with a heated O2 sensor with long tubes. How did you wire it?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I think it only draws up to a half of a amp.
i would think the o2 should see 5-600f to become active.
According to my tunerpro data logs the O2 has to hit 500°f to become "ready". Both my heated ones only preheat to 399ish then climb to around 430ish. That's still too low and keeps kicking an error code 13.
I have the power drawing off the MAF power wire and the ground to a chassis ground stud I installed that's connected to the engine block ground strap and to the negative battery cable.
Car: 1991 Z28 Vert
Where is the sensor located or how far from the cylinder head? In stock configuration they came with a non-heated sensor so I'm hesitant to say your codes are because of the sensor itself
Engine: Lb9
Transmission: M20
Code 13- This code is set by a O2 sensor problem. It is normally set when there is a open circuit or the O2 sensor is coated with soot from a over rich
Transmission: 5-speed/T-5
Where are you getting the sensor temperature from?
Also as Tuned Performance is pointing out, code 13 is not to do with sensor temperature, but a circuit problem usually, and low activity will sometimes set it.
The sensor is in The "stock" location. Roughly 12 inches from where the 2 legs come together.
the temperature is coming from the "converter temperature" reading in tunerpro RT.
So do think I should check wiring next? I got a new sensor figuring maybe it fouled when the car was running like garbage before but the new sensor does the same exact thing.
The main reason I was wondering about the temperature is because Tunerpro doesn't see the sensor as "ready" until 450-500. If the car runs 5-10 minutes with the o2 sensor as "not ready" it kicks code 13
The "temperature" in TP is simply a calculation, not actual temperature. I don't know how it derives this number but it's useless IMO.
Yes, check the wiring, especially the signal wire.
Car: check
Engine: check
Transmission: check
I found the problem last night. When I installed the 3 wire O2 I apparently forgot st solder the signal wire. Both the power and ground wires were soldered which makes it weird.
after soldering the signal wire too it works fantastic, I didn't even make it out of the garage before the O2 sensor was "ready"
Thank you everyone
