Just driving along wheeeeeennnnnnnn..........
Old Dec 4, 2018 | 10:58 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
2.8v6 1988 cruising at 60 . Backfires , dosnt respond to throttle and dies on a really bad road for this to happen , it woke me up quick that's for sure , got it going again , felt spot on then did the same again all the way to work like this . Raining today . Any quick checks clues would be appreciated. 😁
Old Dec 4, 2018 | 11:43 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: Just driving along wheeeeeennnnnnnn..........
I'm guessing the backfire means I'm losing spark , if I make it home (25miles) I'll check in the dark tonight if I can , first time it's happened like this though. Nothings changed . At work now so nothing I can do .
Old Dec 6, 2018 | 11:00 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
when mine did this it was the fuel tank sock getting plugged up with rust.
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
rinsing the tank didn't work. new tank did.
Old Dec 6, 2018 | 11:11 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Oh dear ! Hope it's not that what a pita that must have been ! I'm going through the ignition system , tidying up as I go to , a few small jobs I shoulda done . A quick test on the coil last night showed a probable fault. . . . . . It's funny cause I said to a friend the other day it's the last old part on the system , I should prob replace it , but it's working ! Doh !
Old Dec 7, 2018 | 07:58 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I hope the coil fixes yours but honestly I don't know how all these wouldn't need a new tank by now.
Old Dec 7, 2018 | 08:50 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The only time I've had my car just die at hwy speeds it has been the ignition control module in the distributor. I would replace the ignition control module, coil, and new distributor cap/rotor, wires/plugs... basically an over kill tune up. And put in a new fuel filter.
Its also possible the fuel pump is going if you have a gauge I would check pressure. I've looked inside my old tank when I replaced it with a plastic tank from a 2k last year and it was perfectly clean, but if yours has crude and rust in it then replace it.
Old Dec 16, 2018 | 01:53 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Shortened some lengthy flappy HT leads, new coil, plugs re gaped . Runs pretty strong again . Dare I say the fuel pump is prob next ? Lol .we will see. Happy driving !
actarnoff
Members Camaros
Oct 2, 2012 05:12 AM
andynice20
Apr 5, 2002 08:41 PM
scauffiel
Jul 5, 2001 12:56 AM
iroctpis
Mar 26, 2001 12:06 AM
gruveb
Mar 19, 2001 09:00 PM
