2.8L-3.1L V6 Intake Manifold Porting Guide
Old Feb 14, 2019 | 10:14 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Here's something that would've helped me and might help someone else understand all the areas of concern when port matching the intake manifolds. It's not professional and it's not to scale, but I made it and thought i'd share.
If you have a dremel tool and a few free nights, this is an easy & cheap way to pick up a horse or two.
All of the Felpro intake gasket sets I've bought for this car have bad overhang from the top piece to the middle. This needs to be trimmed.
NOTE: Ignore the part about the intake port fin. I've removed my intake fins since i'm going turbo. This is not recommended.
NOTE: First pic of the assembled intake assembly is actually from a Fiero. The throttle plate is different among other things but the basic design is the same.
Old Feb 14, 2019 | 10:32 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Re: Intake Manifold Porting Guide
there are also casting lines deep in the lower intake that need to be smoothed out. hard to get a pic of this but you will feel it with your fingers.
Old Feb 14, 2019 | 11:42 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 2.8L-3.1L V6 Intake Manifold Porting Guide
When I ported mine, I noticed a big difference above 4500RPM. There wasn't that big drop off in power. I had access to a flow bench so I was able to balance each runner's CFM flow. It's a great upgrade for very little cost, just time.
Old Feb 14, 2019 | 12:05 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I am working on my V8 base doing the same. When you ported yours, did you change the injectors or did you reuse the old ones?
Old Feb 14, 2019 | 12:07 PM
drdave88's Avatar
Engine: 6.0L
I had already swapped in the 3.4 so I had 3.4 injectors.
Old Feb 14, 2019 | 12:46 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
yeah I don't think it would improve airflow enough to necessitate larger injectors.
Old Feb 14, 2019 | 01:01 PM
vinny R's Avatar
Car: 1991 Z28
My thought also, I am not so much concerned with uping the injector size. It is more do I put 30 yr old injectors back in. Multecs to boot!
Old Feb 14, 2019 | 01:02 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
yeap. it would be nice to get them flow tested to make sure you don't have any cylinders running lean.
Old Feb 15, 2019 | 06:30 AM
drdave88's Avatar
Engine: 6.0L
Here is the post I did back, wow 2006, I feel old now. Anyway, the flow numbers start at post 21.
https://www.thirdgen.org/forums/v6/3...ed-intake.html
Old Feb 15, 2019 | 07:49 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
For the lazy people, drdave's results were:
BEFORE
Runner 1: 157.8cfm
runner 2: 143.6cfm
runner 3: 141.3cfm
runner 4: 149.3cfm
runner 5: 152.4cfm
runner 6: 143.1cfm
intake/TB assy: 418.7cfm
AFTER
Runner 1: 165.7 cfm
Runner 2: 162.9 cfm
Runner 3: 166.9 cfm
Runner 4: 162.0 cfm
Runner 5: 160.4 cfm
Runner 6: 161.7 cfm
Intake/TB assy: 432.2 cfm
Old Feb 15, 2019 | 07:50 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I wonder why runner 1 flowed so much better?
Old Feb 15, 2019 | 07:53 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
and Drdave, did your gaskets fit as bad as mine, and did you have them trimmed on your before test?
Old Feb 15, 2019 | 08:04 AM
drdave88's Avatar
Engine: 6.0L
I didn't trim the gaskets at all. I don't recall having any spots where the gaskets hung over the ports at all, I probably would have trimmed them otherwise.
Looks like Cardomain has updated their site since I added those pics, so everything is a mess on there, as far as trying to find the pics I had of the port work I did. Nothing is in order and the pics don't go along with the text that is displayed anymore lol.
Old Feb 15, 2019 | 10:03 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
yeah I have that problem when stalking people's pages. it seems not many people have messed with these old engines in a while. Even a lot of the old posts on here that had helpful pics no longer exist. I never understood why you had to have an online image host instead of uploading them directly to this page. frustrating.
I guess it was due to server limitations.
I also don't like how now when you scroll down you run into a "related" thread. I want the bottom of the page to be the bottom of the thread you're on.
Old Feb 15, 2019 | 10:08 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
can you elaborate on the CFM of the total assembly and help me understand why that doesn't equal all of the runner's individual CFMs put together?
Old Feb 15, 2019 | 07:27 PM
OrangeBird's Avatar
Car: 1989 Firebird
If you scroll down to the blue header that says "Related Topics" and click on the little round symbol on the right hand side , you can "collapse" the related threads . The blue bar will still remain but the related threads themselves will disappear .
Old Feb 16, 2019 | 09:53 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
thanks for the tip orangebird.
here's a pic of my lower intake manifold after porting.
Old Feb 17, 2019 | 07:13 AM
vinny R's Avatar
Car: 1991 Z28
What type of cutters are you using? Also do you plan on going back and smoothing those tool scratches out?
Old Feb 17, 2019 | 04:08 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
i use carbide to start, then sanding cones and then sanding paper rolls. its pretty smooth to the finger. it looks worse than it is. ive been doing a lot of reading on air flow and air actually flows easier over a slightly rough surface. it creates a boundary layer that the air flows freely over. so I'm not too worried about it
Old Feb 17, 2019 | 04:10 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
look up veicomer . same principle
Old Feb 18, 2019 | 05:41 AM
drdave88's Avatar
Engine: 6.0L
Sorry, for the delayed response. If I remember right, that was about the max that intake can flow in at a time, so that's all that can come out. I remember having that same question to my teacher too when I saw the results.
I'll see if I can find the actual project for it, I had a whole write up printed out for the project. I may have some more details in there about it.
Old Feb 19, 2019 | 07:48 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
thank you, i'd love to see that.
Old Feb 20, 2019 | 01:43 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
i guess what it means is the neck can only pass so much air to share with each of the runners.
Old Feb 21, 2019 | 05:28 AM
drdave88's Avatar
Engine: 6.0L
I couldn't find it, must still be packed away with old stuff at my parent's house. But that's pretty much what I remember is that the throttle inlet/intake opening could only flow that much so that's all you can get. Since you aren't flowing all 6 runners at the same time you wouldn't need that much air going in anyway.
Old Feb 21, 2019 | 11:59 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
which means the individual runner gains are much more impressive and useful than the total assembly cfm
tshack
Jan 12, 2009 01:14 AM
MrJ
Aug 3, 2006 06:57 PM
justlearning
Sep 30, 2005 10:18 AM
Casey_Butt
Jul 3, 2005 09:23 AM
V6camaroman
Apr 16, 2002 07:29 AM
