Vacuum hose problem
Old May 10, 2019 | 09:29 AM
Redcamaro88's Avatar
Vacuum hose problem
Does anyone know where this vacuum line is supposed to go ?
Old May 10, 2019 | 02:55 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Vacuum hose problem
Yes indeed I do , it's supposed to connect to a piece of solid plastic tubing that is bundled in with the heater/AC wiring harness that exits the firewall . You may notice with that not connected the heat/AC blows out of the defroster vents only and not out of the dash vents or the floor vents , this is the default "failure mode" of when there is no vacuum applied to the heat/AC to ensure a clear windshield . Also , right at where the 90 degree bent rubber boot meets the valve there is broken off a second vacuum connection that's supposed to go to the vacuum storage ball that lives under the battery tray (jokingly called "The Orb of Power" by enough people that a search here for it will produce results) . With that being open like that you have a vacuum leak that could very well produce a crappy (choppy) idle .
Old May 10, 2019 | 07:07 PM
Thanks for the response is this “orb of power on the 2.8 l camaros or are is it only on the v8
Old May 10, 2019 | 07:23 PM
OrangeBird's Avatar
Car: 1989 Firebird
Your welcome , and yes , it's supposed to be on any third gen with a vacuum operated HVAC system regardless of the engine's number of cylinders .
Old May 10, 2019 | 07:41 PM
Ok ,much appreciated
Old Jun 4, 2019 | 12:02 PM
Hey I know it’s been awhile but I finally got a chance to check out the storage ball and I don’t have one ,so are there only certain years that have one ?
Verhagen82
Nov 5, 2012 09:56 PM
steve8586iroc
Mar 26, 2004 01:00 AM
Homer
Aug 13, 2002 01:48 PM
breathment
Mar 18, 2002 07:47 PM
jm91rs
Jan 29, 2002 11:28 PM
