3.1 "chugging" from 1500 to 2500rpm
Old Jul 15, 2019 | 12:13 PM
steves1967's Avatar
My sons 92 Firebird, it has the 3.1l in it. The car will start to "chug" between 1500 and 2500 rpm. When I push the pedal to the floor it doesn't do it, only at part throttle. I've replaced the Fuel Injectors (new set from Southbay), Coil, ICM, Cap, Rotor, Plugs, and Wires. The car doesn't throw any codes. Doesn't smoke or smell funny. The engine just isn't happy. I cant find any vacuum leaks- and it only doesn't it under a load. When it starts to chug, if you put it in neutral the car revs just fine.
Any ideas what I should check or replace?
Old Sep 9, 2019 | 01:58 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Re: 3.1 "chugging" from 1500 to 2500rpm
when you're pushing it to the floor to make it stop chugging , is this going down the road, as in under load?
Old Nov 3, 2019 | 04:42 PM
steves1967's Avatar
Under load going down the road.
Update- replaced the fuel pressure regulator and all seems to be fine now! fingers crossed!!
Old Feb 18, 2020 | 02:19 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
I'd avoid working with or helping this guy out at all costs. Nothing but a crook. Stole money from me several years ago and vanished.
Old Feb 19, 2020 | 03:52 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
comment deleted
Caleb_91RS
Mar 5, 2015 03:33 AM
chikenbag
Feb 2, 2013 12:49 PM
jl112799
Jan 15, 2006 12:17 AM
Firebat
Aug 30, 2005 07:18 PM
87 Firebird
Jan 6, 2003 07:17 PM
