3.1 dies occasionaly
Old Aug 15, 2005 | 09:53 AM
Firebat's Avatar
I was driving 85 on the interstate with the 3.1 V6 and it just started cutting out on me. I pulled over and it died. Got it started again and i could only get it up to 3000RPM, drop it in first gear and get up to a top speed of 10MPH for 10 seconds before it would die again. I repeated this 3 times before i let it sit for 5 minutes. I started it and it drove fine. I had less than 1/2 tank of gas so i went and got some gas. Took the cap off and it hissed for a few seconds.
My engine was running hot - 220 degrees. I looked and i'm missing an air dam. It was about 100 degrees outside too at the time.
Anyone know what this problem could be? Fuel, air?
Old Aug 15, 2005 | 11:55 AM
mvftw's Avatar
Replace your distributor module first...fast & cheap...
Old Aug 15, 2005 | 02:57 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Fuel injectors. Gauranteed. I had the same problem with my 3.1. Tried everything from alternator, cap & rotor, spark plugs, etc. Finally I spent the money to have a dealership check it out, and that was it. I spent $65 or so on a used set of injectors and it ran fine. I actually have a set of injectors from my 3.1 (swapped to 3.4) if you want them.
Old Aug 17, 2005 | 05:54 PM
Firebat's Avatar
FYI. I had the car die two summers ago, doing the same things.
Since then i've replaced the cap&rotor, twice. Replaced the spark plugs, twice. Replaced plug wires, fuel filter.
I'll look into injectors.
Old Aug 17, 2005 | 06:37 PM
Drew's Avatar
Don't discount the fuel pump.
Old Aug 17, 2005 | 08:09 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Rebuild your distributor replacing your ignition module and pickup coil. Do a search on the board for the instructions. Best deal as far a payback in renewed power for the effort. Most of these drivability problems are ignition related. Remember these cars range in age from 13-23 years old, and the only ones that don't need a distributor rebuild are the ones that have already had one.
Old Aug 17, 2005 | 10:17 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
definitly get that air dam back on either way though, they are vital in getting airflow through the radiator on bird's. and a radiator isnt much good if you dont have any air flowing over it!
probalby isnt causing your problem, but you will see power, fuel economy, and engine life decrease significantly without an air dam(if your car came with one, i think a few of the firebird nose cones might have been designed not to need them, but i know mine needs it.
Old Aug 18, 2005 | 12:46 PM
Firebat's Avatar
yeah i'm looking for an air dam. didn't realize i didn't have one on the V6 until recently. And i've been daily driving it for 2 years.
Old Aug 23, 2005 | 11:23 AM
Firebat's Avatar
FYI
Figured out the 220-225 degrees problem. On top of not having an air dam, the fan doesn't turn on anymore. I have a spare fan and an air dam on the way.
Old Aug 30, 2005 | 04:50 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
I'll bet on the ECM prom
Horst
Old Aug 30, 2005 | 02:51 PM
Firebat's Avatar
Horst
for which problem? car shuting down, or fan not turning on?
Old Aug 30, 2005 | 07:01 PM
KED85's Avatar
IF you have working AC try it to activate the fan
IF no AC then you MUST burp your cooling system, cause it's very good chance you have an air bubble at fan sensor area and that's causing fan to not come on.
How you've gotten away with driving without the air dam is beyond me..
Shutting off while driving can be due to heated up engine.
Can also be ignition coil if original. AGED Overheated coils die easily & "live again" upon cooling....
Can also be fuel pump dying, soon....
Where do ya start?
Get air dam & try borrowing the fuel pressure gauge to eliminate the fuel pump question (it's 40-ish PSI when activated by ignition key).
Keep eye on temp guage while driving & cross fingers.
IF no fan on, then start there by burping cooling system
How?
Remove radiator cap & just turn on engine & let it heat up.
When the "stuff comes outta radiator", you've burped system.
Everytime car overheats, it'll tend to create an air bubble in cooling system and fan switch does not activate in "air", only when cooling system is full of water.
Old Aug 30, 2005 | 07:18 PM
Firebat's Avatar
thank goodness i'm going to home tomorrow. At least there i have a garage. Going to flush the radiator, take the air dam off of the project car then put it on the v6, figure out what the hell is wrong with the fan, put in a 180 thermostat.
When i drive it on the interstate it cools to normal temp as long as i don't have ac on, so i'm confident i'll make it back home. Its funny the hottest it gets is 220 around town and sometimes it cools down to 195. I've gotten by without an air dam for 2-3 years because i haven't driven it in the summer a lot and my fan has been working til now.
Thanks KED85, i wouldn't have thought of checking fuel pump pressure.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
