LH0 hesitation and misfiring. Linked video.
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Hi guys,
need some help to solve this kind of misfiring and hesitation from my LH0 V6. When hot starts to behave like in the linked video, and sometimes this issue causes a stall. As you can see, the Y-pipe is cracked and I disconnected the oxygen sensor and I got no ECM code. I replaced the most of components without solving. Just the stock injectors are still to be replaced. Some people suggested me to change the Y pipe (because the EGR valve (digital) has wrong parameters from the oxygen sensor) but it' s nearly impossible to find. it' s a WALKER 40442.
Any help is really appreciated! Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: LH0 hesitation and misfiring. Linked video.
Have you attempted to ohm the injectors engine warm ?
is the icm new ?
a heated o2 might help but without a scanner to see what’s going on it’s hard to tell.
is the icm new ?
Engine: 3.1 LH0
Thanks for you reply! I replaced the ICM some days ago with the pick up cool, I measured the injectors at cold not warm. Tomorrow I’m going to scan the car, I’ll put some screenshots ASAP!
Engine: 3.1 LH0
Here' s the scan. it' s a TunerPro file, should work. Thanks!
Engine: Lb9
Transmission: M20
do you have a xdl you can zip ?
error 54 ?
error 54 ?
Engine: 3.1 LH0
Here it is, thank you very much. Hope to solve this issue finally!
Engine: Lb9
Transmission: M20
You might want to check pump voltage at the tank, ops and ecm pin e13
Engine: Lb9
Transmission: M20
im not sure why but when I download the .zip it just shows as a rar file
Engine: 4++,350 & 305 CIs
That Y-pipe looks like a broken mess. Could seriously be messing with the afr..
Engine: 3.1 LH0
What do you mean for ops?
I’ll upload the file in zip instead of rar
Engine: Lb9
Transmission: M20
You can check voltage with a volt meter.
Here is a flow chart. If you come to the ecm pin test it’s not b2 like stated in this chart it should be e13 a grey wire at the ecm.
the engine looks like it’s running rich.
i do t see the reason why. Could be a exhaust leak by the o2.
the o2 is active . Pump voltage is 13.4-13.8 so I’m not sure why it’s throwing a code could be a bad ecm.
http://chevythunder.com/fuel_pump_code_54.htm
Engine: 3.1 LH0
I just bought the new pipe, I’ ll make a new read when It ll install it into the car. Thanks for the chart, I replaced a new fuel pump recently but I noticed the fuel pump relay wires were spliced to install an anti-theft system. Maybe the problem is there?
Engine: Lb9
Transmission: M20
Are you running headers ?
just curious why someone relocated the o2 so far down.
Engine: 3.1 LH0
I think they’re stock, I was told the engine head is from a 2.8 instead of 3.1. Looking at the pipe pic the O2 position seems the same. Today I’ll perform the voltage drop test, I’ll let you know. Thank you very much!!
Engine: 3.1 LH0
[QUOTE=Tuned Performance;6339017]Have you attempted to ohm the injectors engine warm ?
How do I perform the test? I have to remove the plenum to do that?
