Replaced coolant temp sensor but still no temp reading on dash cluster
Old Nov 5, 2019 | 08:44 PM
89camarov6's Avatar
Car: 89 camaro and 05 gmc canyon
Engine: 2.8
I replaced the engine coolant temp sensor (one under the throttle body) but my temp guage still reads nothing, the pin is all the way on top past the red block , I took the cluster apart and wire rushed the pegs on the back thinking that might fix it but it did not.the needle is not stuck bc when I took the guages out I moved it down thinking it was stuck, now I am lost the only thing I can think of is running the wires from the connections and making sure it's not melted or cut? Or possibly changing the temp gauge? Anyhelp would be appreciated
89 camaro 2.8 v6
Old Nov 6, 2019 | 04:47 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Re: Replaced coolant temp sensor but still no temp reading on dash cluster
I'm not sure about the 2.8, but on my 3.4, there are 2 temp sensors. The one under the throttle body and one in the cylinder head.The one in the cylinder head is used for the temp gauge. I believe it's a one wire sensor.
Old Nov 6, 2019 | 06:44 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
The sending unit for the gauge, and the sensor for the ECM are 2 different things...
Old Nov 6, 2019 | 09:02 PM
89camarov6's Avatar
Engine: 2.8
Ok, where's the ecm and you think that's what's causing the guage not to work?
Old Nov 6, 2019 | 09:12 PM
T.L.'s Avatar
The ecm does not control the gauge, so if you replaced the temp sensor, it would have no affect on the gauge. You need to replace the temp SENDING UNIT in the cylinder head...
Old Nov 6, 2019 | 09:14 PM
89camarov6's Avatar
Engine: 2.8
Ok thanks
Old Nov 7, 2019 | 08:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
IIRC, the temp gauge sensor is in the front corner of the driver side head. Single green wire.
RBob.
Old Nov 7, 2019 | 11:08 AM
OrangeBird's Avatar
Car: 1989 Firebird
There are actually 5 devices monitoring temperature on an 89 V6
#1 Intake air temperature / ECM
#2 coolant temp / ECM
#3 coolant temp / CSI
#4 coolant temp / dash gauge
#5 coolant temp / radiator fan
camarod24
Jan 9, 2008 11:21 AM
diabolik
May 3, 2006 07:37 PM
Cliff92Z
Nov 14, 2004 11:01 PM
ZFORCE
Jun 5, 2003 05:17 AM
