Need help with a sensor on passenger side of motor behind the head.
Old Jul 15, 2020 | 01:17 AM
Billy Downer's Avatar
My baby
Need help with a sensor on the passenger side of the engine on the head, Its a line coming off of it and I cant figure out what it is, Im taking apart the motor tomorrow to put in new push rods but want to know what this sensor is so I can buy a new one for it Thursday, Had this car for a year and barely drove it much. Has a 2.8 in it with 40,000 original miles
Has a vacuum line but no line going to it. This is frustrating cause I bought so much stuff for it but cant really do anything till its running good.
Old Jul 15, 2020 | 06:01 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Need help with a sensor on passenger side of motor behind the head.
Dude , with all due respect , , , , , If you can post pictures of "My Baby" , you surely must be able to post a far more important picture , namely a pic of exactly WHAT it is your trying to identify ????
I THINK it could be the temperature switch that runs the radiator's electric fan in the event the ECM fails to , but without that all important pic all your gonna get outta me is an "I think" , VS a 100% solid identification of just what it is your looking at .
Old Jul 15, 2020 | 09:46 AM
Only pic I had at the moment, Doing that after work...
Old Jul 15, 2020 | 09:08 PM
This sensor... I want to get it running again and I need to know if this affects it running well or not.
Old Jul 18, 2020 | 02:18 AM
Really? No one is gonna help a guy who always wanted a camaro? Some forum
Old Jul 18, 2020 | 02:41 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
The V6 section gets very little traffic. You'll have some patience.
Old Jul 18, 2020 | 07:27 AM
BIRD91ZRAG's Avatar
What color is the wire/ wires going to the sensor?
Old Jul 19, 2020 | 03:23 PM
None as I can tell. Its just a vacuum line coming off of it, Plugged it and it seems to run better but my lifters are ticking so im not sure if it helped or not.
Old Jul 19, 2020 | 08:06 PM
OrangeBird's Avatar
Car: 1989 Firebird
Sometimes life gets in the way of a quick answer , this past week I was tied up with a set of Ford 4.6 timing chains
Now , what your looking at is not supposed to have any vacuum hoses connected to it , it's (what's left of) the radiator's fan switch that is supposed to engage the fan if the ECM doesn't . I say "what's left of" because the metal pin you see in your pic is actually the electrical contact in the center of the nice new switch in this pic I stole from Rock Auto of what your switch is supposed to look like if the plastic wasn't all smashed off of it .
There should be a wire hanging around somewhere in the general area with a connector that'll fit over what you see in my picture ........
Old Jul 19, 2020 | 08:37 PM
BIRD91ZRAG's Avatar
Good job orange. The connector end will look something similar to what the connector on the brake valve under the booster looks like. Should have a green or green/white trace wire to it.
Old Jul 21, 2020 | 01:28 AM
Thanks guys, sorry if I came across as like a jerk, I just want to get her running again, Kid before me messed everything up on it, timing was 180 off, o2 sensor was sheared off, valves are tapping, only thing he did was put a new light switch in and even messed that up.
Old May 5, 2021 | 07:52 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Looks like the knock sensor to me...?
Ozz1967
Nov 12, 2019 08:48 PM
MBcamaro1990
Jan 6, 2009 10:59 PM
egplain
Sep 23, 2007 07:12 AM
warrior_91
Nov 10, 2005 05:00 PM
Ivon1877
Aug 17, 2004 12:10 AM
