Diagnose leaking injectors for "hot soak" problem?
Old Jul 24, 2020 | 06:35 PM
cosmonautpg's Avatar
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
Hi all -- 1992 Camaro V6 3.1 here. It looks like a common issue is the "hot soak" problem (see this thread).... no problem with a cold start --> drive normally --> park and turn off --> try to start again --> lots of cranking and difficulty to get started.
Is there a way to diagnose leaky injectors before I dive in and do the work/open her up? If not, I'm 99.9% sure they are the originals so it makes sense to replace them *anyway* but I always like to try to do a diagnosis/measurement first, if possible.
Thanks!
Old Jul 24, 2020 | 11:13 PM
jczoka's Avatar
Car: 1991 Z28 5spd
Re: Diagnose leaking injectors for "hot soak" problem?
The dealer method at the time was to pull them up with the rail and fuel lines still attached. Upper plenum removed of course. Put paper towels under the tips and key on (NOT ENGINE START) To prime the fuel pump. Then let it sit. If the paper towel gets any fuel on it, it will disperse and be noticable under the leaking injector. It's very difficult to diagnose it with a gauge only because it could leak down from the pump or regulator while sitting, or if it is an injector you won't know which injector it is.
Old Jul 25, 2020 | 10:18 AM
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
This makes sense, thanks — is there any observable change in injector resistance for leaky versus not-leaky if I start with electrical measurements?
Old Jul 25, 2020 | 06:50 PM
jczoka's Avatar
Car: 1991 Z28 5spd
If an injector leaks it's purely on the mechanical side if the injector.
Resistance measurements only tell you the condition of the windings without load. It won't tell you if it is flowing correctly or how the injector is working when energised.
Kuma
Aug 25, 2012 01:35 PM
92rsbowtie
Nov 14, 2004 10:37 PM
Stan
Apr 14, 2004 01:11 PM
IROCKER
Jul 9, 2002 01:06 AM
