86 firebird 2.8 no start [SOLVED]
Old Apr 18, 2021 | 03:04 PM
Hellrockets's Avatar
[Solved]
All started when I was driving home from work, car died. Did some diagnosis and found out I had no fuel, fuse was fine relay wasn't, replaced relay, still no start, check pump, pump was bad, new pump, still no start.
I got it to work for about 30 seconds when the realy stopped working. The fuse is still fine and I even tried a different one, any help is appreciated.
Old Apr 18, 2021 | 04:23 PM
Re: 86 firebird 2.8 no start
After some more digging I learned there was no power to any of the connections at the relay
Old Apr 18, 2021 | 06:39 PM
OrangeBird's Avatar
Car: 1989 Firebird
Here is your wiring diagram for your engine. Your fuel pump relay's orange wire should have +12V on it at all times, it gets this power from the fuse called "Inline fuse 3 20A" which is under the hood. Your next check should be that fuse, it's a black plastic kinda nondescript looking thing hanging around the right (passenger's side) fender.
Old Apr 19, 2021 | 07:02 AM
That was the one, thanks a bunch man
Old Apr 19, 2021 | 11:45 AM
OrangeBird's Avatar
Car: 1989 Firebird
Your Welcome, and thank you for letting me know what you found.
86recaroTA
Apr 27, 2011 11:09 AM
0pyders
Aug 31, 2010 04:56 PM
lilbanger
Mar 14, 2007 10:06 AM
jared C.
Sep 14, 2003 01:21 PM
PONTIAC86style
Jul 7, 2003 04:05 PM
