can't set ignition timing on 2.8l V6
Old Jul 11, 2022 | 06:18 AM
Trans-Am 435's Avatar
Car: 87' T/A, Formula Hood, Notchback
Engine: stock 5.7 TPI
Transmission: T56, 7.25" triple disc clutch
Axle/Gears: B/W 3.23,Locker adj.sway Herb Adams
Hi fellas,
Actually i'm not working on a F-body, but on a 1987 Fiero, that from the engine and electrical point is pretty the same as the F-bodies.
I had the heads removed due to a broken spark plug on the left (front) bank, new gaskets, sensors distributor etc. etc.
Engine is back together, started and runs just from the first try.
only issue so far was a code 22, after seting the tps to 0.54V at closed this is fine too.
My problem when trying to set ignition, as soon as i disconect the esc wire, the engine dies.
no spark, no injectorpulse, no fuelpump........
as soon as the esc wire is back on everything operates like it should. i just can't set the ignition timing that way.......
any ideas, suggestions????
Old Jul 11, 2022 | 09:33 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: can't set ignition timing on 2.8l V6
This might help:
Xipher
Apr 14, 2015 03:33 PM
hdis2002
Feb 11, 2012 05:58 PM
Timothayyy
Jul 20, 2011 05:22 PM
j88l98irocz
Nov 26, 2005 01:38 PM
Ackattack1
Jun 4, 2005 12:54 AM
