Question regarding ignition switch/starting problem
Old Jul 25, 2023 | 09:30 PM
Blaise Massey's Avatar
Car: 1990 Camaro RS
Engine: 3.1L V6
So my 1990 RS Camaro does not start at all, relay clicks and it’s over, so far I’ve had the starter and battery tested, both good. I’ve cleaned the battery cables and checked grounds. It turns over when you jump the starter with a screwdriver but it’s relatively slow,( but the starters new) So my question is, I pulled the ignition cylinder out and the two white wires are cut in half and disconnected. Does the car need these to start? If so can I bypass it somehow? I already have the starter relay with a jumper wire as well.
Old Jul 26, 2023 | 10:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Question regarding ignition switch/starting problem
Probably not needed as they are to read the key for the VATs system. Which sounds like is also already bypassed.
RBob.
Old Jul 26, 2023 | 11:10 AM
Car: 1990 Camaro RS
Engine: 3.1L V6
RBob.
Thanks, it is bypassed I just wasn’t sure of whether or not that needed to be plugged in still. I think the battery might just not have enough cca’a left so I’m gonna try jumping it with my other car
Old Jul 26, 2023 | 08:41 PM
Car: 1990 Camaro RS
Engine: 3.1L V6
New update, so that didn’t work. I’m out of ideas, if it isn’t the starter, start relay, batt. cables, battery itself or the wire on the ignition switch is there anything I’m missing?
ajg89
Oct 20, 2022 09:39 PM
Jordan Dorn
Jul 10, 2017 01:49 PM
Mafian
Nov 19, 2012 11:10 PM
STOLEN RS
Oct 30, 2006 09:03 PM
Joshua Leslie
Nov 25, 2002 05:10 PM
