2.8 to 2.8 Swap Help
Old Jun 26, 2024 | 01:52 PM
MCamaro28's Avatar
I'm looking to replace the 2.8 that was in my 88' V6 camaro but am having trouble actually sourcing a motor. Other than other third gen camaros/firebirds, what else could I get the same motor from? I know the S10 2.8's were built for torque rather than power so it'd probably cause some problems....right? In all honesty I'm fairly new to mechanics and am just looking for some help!
Old Jun 26, 2024 | 02:26 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: 2.8 to 2.8 Swap Help
S10 2.8 had no more tq than the f-bod 2.8. Carb'd versions were probably the same long block. Either way, it would work fine.
Old Jun 26, 2024 | 02:43 PM
MCamaro28's Avatar
Oh, ok. I had originally figured that to be the case until a lady at a junkyard lectured me about all of the differences between the two but I honestly couldn't say whether she was right or not. Thanks!
Old Jun 26, 2024 | 02:53 PM
MCamaro28's Avatar
Also, I had read in some other threads that for the 2.8's, I'd want to stick to a 87-92 motor because those were all externally balanced, while the 82-86's were internally balanced which with my car being an 88' would cause some problems, right?
Old Jun 26, 2024 | 03:38 PM
OrangeBird's Avatar
Car: 1989 Firebird
All you need to know about 2.8 swaps, in one handy thread......
https://www.thirdgen.org/forums/v6/4...swap-read.html
Old Jun 27, 2024 | 03:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The only item I can throw into this mix is the flex-plate/flywheel bolt pattern. Didn't it change in '85 or so? Do check this as I may be wrong, but better safe then sorry.
RBob.
Old Jun 27, 2024 | 04:51 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I think the truck / S-10 2.8s had a slightly different cam so the power band is more in the lower RPM or something. .but I doubt you'd feel much difference with the RAW POWER of any 2.8....
Old Jun 27, 2024 | 07:16 PM
Engine: LT1, L400
2.8's have no tq....2.8's have no power. According to Wiki, the truck and the car both had 125 hp on early/carb'd engines, Late (OP's car) should have been 135 horse, IIRC. They'll "git the car on down the road", and that's about it. ....And that's all they need to do.
cIaRmOaCrZo
Sep 11, 2010 05:57 AM
ovalman171
Apr 5, 2010 03:30 AM
swade83
Dec 2, 2008 07:56 PM
trans_am_ta_84
Jan 8, 2004 12:22 AM
